Results 1 to 17 of 17
Thread: No swg amps
    Jun 2016
    Springdale
    8
    No swg amps
    Have an aqualogic swg, new t cell 15, instant salt says 0000 ppm actual is 2700 or so. Also get very low salt error. Voltage at 30.81, amps at 0. Anyone have any ideas what could be wrong?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: No swg amps
    Have you tried a reset? In the menu with the salt/volts/amp display, press the + button. If it comes back as 0 amps, there is a disconnection somewhere and probably at the cell. Do you still have the old cell and was it somewhat working at the end? You could swap them and see if you get any current at all.
    Mark
    Jun 2016
    Springdale
    8
    Re: No swg amps
    Old cell showed the exact same thing
    Lagoon shape inground pool. roughly 36,000 gal
    vinyl liner. Hayward aqualogic, SWG
    Sand filter
    Jun 2016
    Springdale
    8
    Re: No swg amps
    Just tried that, still have same reading. Took board out, all solder joints look good
    Sand filter
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: No swg amps
    So if the old cell showed the same thing, I would guess it is a board issue and probably one of the relays.
    Do both polarities (+- voltage) show the same thing?
    Mark
    Jun 2016
    Springdale
    8
    Re: No swg amps
    Yes, apparently it's not reading the salt level either. So, it's probably going to require a new board?
    Sand filter
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: No swg amps
    Salt level is determined from the voltage, amps and temperature so if there are 0 amps, there will be 0 salt level.
    Sometimes you can fix those boards if you have the skills. There others on ebay that will do it for a price.
    Mark
    Jun 2016
    Springdale
    8
    Re: No swg amps
    Thanks!
    Sand filter
    Re: No swg amps
    Try this: Go to Settings and turn off superchlorinate and turn the percentage to 0. Wait 30 seconds. Turn percentage to 100%. Then go to diagnostics to see the numbers. Watch for 30 seconds. Press the right arrow. Press +. Report results.
    Also, 2,700 ppm is too low. You should be above 2,700.
    What is the water temperature?
    How are you testing salinity?
    Support the site
    Jun 2016
    Springdale
    8
    Re: No swg amps
    Same results, 31.8 volts, 0 amps, 0000 ppm salt. Using sea scape test strips and local pool store for salinity. They are within 100 ppm of each other. Water temp is 81. Tried with old cell and new cell. Results are the same
    Sand filter
    Jun 2016
    Springdale
    8
    Re: No swg amps
    I know 2700 ppm is too low, salt system hasn't worked since I had to repo the house from the ex wife last year. Am just trying to keep it from being a money pit....lol
    Sand filter
    Jun 2016
    Springdale
    8
    Re: No swg amps
    I very much appreciate all the help
    Sand filter
    Re: No swg amps
    What does the average salt show?
    The voltage is measured after the relay, so we know that the system is calling for production and closing the relay. Since the cell is new, we can assume that the cell, cord and plug are probably good.
    Therefore, I think that there has to be a defect in the wiring from after the relay to the plug receiver.
    You can check for voltage at the plug receiver. The top two connection points should measure the same voltage as displayed in diagnostics.
    Putting your voltmeter leads on the top two points should show about 30 volts DC.
    Support the site
    Plano, TX
    11
    Re: No swg amps
    Quote Originally Posted by JamesW View Post
    Having same issue. Tried a friends known working cell, same situation 0 amps. Also my cell seems to work on his setup. What is the path between relay and plug to check for possible opens before buying a new control board?
    Just checked the top two pins as suggested and getting 2.2V vs readout of 30+ on the controller
    13K gal freeform with spa and waterfall, IG pebbletec, Jandy ProStealth 2HP single speed pump, Jandy ProMP 1.5HP waterfall pump, Pentair FNS Pro 60 DE filter (replaced 2016), Aqualogic PS8 with SWG, Polaris 280 with separate booster pump, Rheem 400kBTU heater (replaced 2015). Built August 2004. All original equipment except salt cell heater and filter.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: No swg amps
    Check the solder joint on the back of the motherboard for burn marks. It is right under the K1 Relay. Sometimes, you only need to re-solder it or bridge a broken trace.
    Mark
    Re: No swg amps
    Measuring voltage at the plug receiver probably won't work because when the cell is unplugged, it usually registers an error and won't try to turn on.
    If the voltage is 30, the relay is probably good.
    Can you post a picture of the screen that shows the readings?
    Support the site
    Apr 2017
    Plano Tx
    1
    Re: No swg amps
    I have the exact same problem, the cell checks out good, even bought new one, but still getting the 0.0 amps 0000 ppm salt reading. I am curious, What was the final outcome for "rwesurfn" or "geepmaley" problem?
