Results 1 to 10 of 10
Thread: Drain Plug stripped
    Oct 2015
    San Diego, Ca.
    637
    Drain Plug stripped
    My neighbor has a filter pump that has drain plug in the bottom of the housing. It has a slow drip. When I try to tighten it, it gets sort of snug then breaks free and needs another full turn, breaks free and over and over again.
    I'm sure he'll never used the drain plug. I'm thinking to get some "Crazy Glue" gel, put it on the threads and pray.
    What do you think?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Apr 2015
    South Central PA
    297
    Re: Drain Plug stripped
    Does it have an o-ring? If not, try putting one on before super gluing it...
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You can generally buy new plugs if it's the plug that is stripped.
    Oct 2015
    San Diego, Ca.
    637
    Quote Originally Posted by 440dodge440 View Post
    The o-ring is there.
    Thanks
    triptyx's Avatar
    Apr 2016
    1,438
    Whether or not I used it, I'd be pretty angry if my neighbor who was watching my pool glued anything shut.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by Philo View Post
    Thanks
    Get another one and double then up. The threads are "popping" past the last thread, hence what you are describing. By doubling up the o-rings, it will snug up before the plug "breaks free". Also get some Magic Lube. Like this:
    or if you have a Leslie's by you, the exact same product repackaged with their name on it:
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Apr 2015
    South Central PA
    297
    You could also wrap with teflon tape. I think it's often not recommended on plastic, but the pool company appears to have used it when servicing the previous owner with no bad effects. It may tighten up the threads just enough....
    Oct 2015
    San Diego, Ca.
    637
    It seems like the threads are "fine grade" and because they are plastic hey collapse on themselves.
    Mar 2015
    US
    122
    If the threads on the plug are stripped, replace the plug. If it's on the pump, you could fill the hole with PC-11 Marine epoxy. Then drill and re-tap the hole.
    PC-11: https://www.amazon.com/PC-Products-T.../dp/B008H4QRPI
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    I'd start with the easiest, and cheapest solution. Try the Teflon tape. And even though the o-ring is still in place, check it for cracks or dry rot. A new o-ring and some tape may do the trick...if not, your only out a few cents and a little time.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
