Thread: I don't understand the pool calculator
    Jun 2016
    wisconsin
    2
    Hello everyone, we recently bought our daughter an above ground pool. It is a 15 ft. x 3 ft. easy set pool, and it holds 2,800 gal. I'm not sure if it is still called the "BBB" method, but that is what my husband and I want to try. This pool is just practice for us until we get our in-ground pool next summer. Would you guys be able to help me figure out how much bleach/borax/baking soda I need? Thanks, have a nice day!
    15 ft. x 36 in. above ground easy set pool.
    Jun 2014
    15,165
    Re: I don't understand the pool calculator
    Hello and welcome to TFP! Since your pool is under 3K, we would first advise you to review the Pool School - Guide for Seasonal/Temporary Pools page. It has very basic info required for a pool that size. Once you get comfortable with that process, you can continue practicing with the Poolmath calculator and also refer to the Recommended Levels/Chemicals charts (links below) for a more comprehensive view of how it all flows together. It may seem like a lot at first, but you'll soon get it.
    Let us know if you have any questions. It's great to have you with us.
    On the calculator, just go row-by-row (FC, pH, etc) and enter your NOW value and TARGET (Recommended Level). Then the calculator will automatically update and tell you how much of something you need to add. When on the FC row, make sure to manually update the bleach percentage (WEIGHT) that you are using (i.e. 6%, 8.25%, 10%, etc).
    Jun 2016
    wisconsin
    2
    Thank you very much!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Here is an instruction sheet for Poolmath, Pool School - PoolMath
