Thread: gas blower 465 CFM and 195 MPH to blow pool lines
    Jul 2013
    Northeast
    128
    Can I use this blower to blow pool lines? Or is it too strong?
    I have no use for this blower and it's missing the carburetor, but if it can be used to blow pool lines I may as well fix it and use it.
    I've been using air compressor and it's been fine, except main drain barely gets any bubbles and I'm not too sure I get all the water out of the skimmers.
    Thanks
    P.S. I never used leaf blowers
    23k in-ground plaster. Cartridge filter Hayward 450 or 550. Hayward 2ph pump.
    liquid chlorine, tablets occasionally when out of liquid and cya allows it. ph down.
    stabilizer (Had no cya last two openings, but never before that)
    no other chemicals used in years
    TF100.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Re: gas blower 465 CFM and 195 MPH to blow pool lines
    If you can a way to attach it to a port, it's actually better than a garage mechanic's compressor. A compressor is high pressure, low volume. Gets the job done, but can be a little harsh on your plumbing. (Same applies to blowing out your lawn sprinklers).
    A backpack blower is just the opposite. LOW Pressure, HIGH volume. Which is ideal for blowing out lines. I finally bit the bullet last year and bought the Cyclone 2 from Amazon:
    25 + year pool owner. Current pool (going on 13th year) - 38K gallon in ground Gunite/White Plaster, Spillover Spa, Hayward Cartridge Filter, Hayward 450k BTU NG Heater, Hayward Goldline Aqua Logic control with T-Cell-15 Salt Water Cell, Dolphin Explorer.
    Jul 2013
    Northeast
    128
    Are you saying air compressor can damage lines? I think I run it at 5 PSI maybe 10 at most.
    how about this blower - is 465 CFM not too strong?
    TF100.
    mikemass's Avatar
    Jul 2013
    Northern Howell, NJ
    485
    Quote Originally Posted by nikon5400 View Post
    No I am talking about compressors in a mechanics garage that operate pneumatic tools at 90 - 120 PSI. 5-10 PSI is very safe and way less than the PSI of water running through lines. So that is fine. But most HPLV compressors, if you can even dial them down that low, probably will not have enough volume to blow out a main drain.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    You could also use the exhaust port on a big shop vac. The backpack blower will work and shouldn't hurt the pipes it may make a mess tho. They are also very effective at cleaning gutters but again with that messy part.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
