Results 1 to 8 of 8
Thread: Pump won't turn on
    Jun 2016
    Lehigh Acres/fl
    7
    Pump won't turn on
    We just purchased a Coleman pool last week and now the pump won't turn on. It has the test and reset buttons on the plug and neither one clicks. Help!!!
    Jun 2014
    15,109
    Re: Pump won't turn on
    Hello and welcome to TFP! Any chance the electrical breaker that control power to your outlet is tripped (off)?
    Jun 2016
    Lehigh Acres/fl
    7
    The pump is an sfx1000
    Quote Originally Posted by Texas Splash View Post
    I have tried 2 different outlets you know how it has 2 buttons on the plug that click of you push them? They don't click, it's not doing anything
    Jun 2014
    15,109
    After reviewing the troubleshooting steps for a basic above ground pool pump, it's possible the cord plug itself may have malfunctioned. You might want to call Coleman customer service since I would think it's still under warranty. You mentioned the pump worked fine last week. Have you used it earlier today at all? Just wondering if perhaps it could've overheated. If not, and your outlets are working fine, then I would call Coleman directly.
    Jun 2016
    Lehigh Acres/fl
    7
    I just put s bunch of chlorine in yesterday before I knew the pump was broke l. Still safe to swim or no
    Quote Originally Posted by Tiffybyron View Post
    Jun 2014
    15,109
    You can swim if the FC level is not over your SLAM FC level for your current CYA reading. Do you know what your current CYA (stabilizer) level is?
    Aug 2013
    Oklahoma City, OK
    139
    Have you checked to make sure you have electricity to the outlet?
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,525
    It's not uncommon for the GFCI to go bad on these little pumps. I've had it happen. I cut mine off and attached a normal plug, since it's plugged into a GFCI protected socket at the house.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
