Thread: Handle broke off / Diverter - Jacuzzi 250
    Sep 2015
    Toronto
    4
    The handle on the filter valve diverter broke off - Jacuzzi 250
    If someone could suggest where I could get the replacement and in the meantime how could I give it a temp fix (without doing any further damage) so I can have the filter back on (it's off now)..help would be greatly appreciated.
    https://s32.postimg.org/j7u7mijj9/20160626_130448.jpg
    https://s32.postimg.org/q0hx83cdx/20160626_130535.jpg
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,262
    Re: Handle broke off / Diverter - Jacuzzi 250
    Welcome to TFP! Good to have you here
    With everything turned off, you can undo those 4 screws in the picture and lift the top assembly of the multiport valve off. From underneath, you may be able to turn the diverter by hand back into the filter position. Then replace it. This is just a stab in the dark; I don't know that filter. But my answer will also bump your thread.
    Parts should be available. Try googling "Jacuzzi 250 filter parts"
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
