Thread: How much pool water/R-0013 for the CYA test
    Apr 2015
    South Central PA
    298
    I have the test bottle from the TF100 kit that says fill pool water to the bottom of the label and R-0013 to the top....does anyone know what the actual volume should be?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Feb 2015
    Chandler AZ
    938
    Re: How much pool water/R-0013 for the CYA test
    You can always fill with pool water to the bottom of the label and then pour that into one of the graduated testing cylinders to get an approximation.
    I remember seeing something about 7ml, but could be confusing that with something else.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Jul 2015
    Tempe, AZ
    194
    I believe you want a 1:1 ratio of pool water to R-0013 reagent. Specific volume doesn't matter provided it's enough for the test and you're not wasting reagent by using too much.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
    domct203's Avatar
    Jun 2015
    CT
    3,597
    FWIW my Taylor CYA mixing bottle is labeled at 7ml & 14ml, a 1:1 ratio (or 50/50 mix) as posted.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Feb 2015
    Chandler AZ
    938
    Quote Originally Posted by domct203 View Post
    Dom
    I knew I remembered 7ml from somewhere. So 7ml from the CYA mixing bottle in the Taylor manufactured kits. I think the TF100 CYA mixing bottle is slightly larger.
    The exact 1:1 ratio is definitely the important part.
    Gene
    Apr 2015
    South Central PA
    298
    Thanks! It's easy to overshoot, so I think I'm gonig to start using a syringe to measure it out. I have a 5ml syringe, so it helps to know the 1:1 rule to make it easier
