Thread: Intex sand filter keeps blowing small amounts of sand into the pool everyday
    MermaidMary's Avatar
    Jun 2016
    West Warwick, RI
    3
    Hello!
    New here. We have an Intex Ultra Frame 14 X 42 that came with the crappy little filter that comes standard. We upgraded to the Intex Crystal Clear Sand filter and pump. This is stupid and probably our problem but when my husband filled it, it came to just about 2 inches below the min fill line with the 50 pounds of #20 sand that we purchased for it. My husband made the call to run it and add some sand when we buy it this week. Everything runs perfectly on it but it blows sand back into the pool everyday. Small amounts, but enough to be vacuumed daily. At least 2 to 3 oz. What would be causing this and will it most likely stop when we add the sand up to the minimum fill level? Thanks
    Intex Sand Filter
    Heritage Wall Skimmer
    Intex Automatic Pool Cleaner
    Jun 2014
    15,027
    Re: Intex sand filter keeps blowing small amounts of sand into the pool everyday
    Hello! A couple things for you to consider:
    - Did you fill the filter halfway with water "before" dumping the sand in? If not, the weight of the sand could have separated a lateral inside.
    - Did you backwash and rinse the new sand really well? That's very important to help it settle.
    Jun 2016
    Celina, TX
    34
    I'm new here and we just set up a 16x48 Ultra Frame using the 2150 GPH Intex sand filter. No problems here. What sand did you use?
    Aug 2015
    Tuttle Ok
    27
    Quote Originally Posted by MermaidMary View Post
    Hello!
    I changed my Intex filter sand 3 times. Different brand each time. I did everything correctly, all three times. Unfortunately, It still put sand in my pool. I replaced it with a Hayward sand filter and so far it is much better. Still trying to get all of the sand out of my pool, but getting better each day. It seems to be hit or miss with these Intex sand filters. Some put sand in pool, and others have great luck with them.
    Scott
    14'X42'' Summer Escapes AGP
    2800 GPH Intex Pump with Hayward S166T Sand FIlter and Krystal Clear SWG
    TF-100 Test Kit w/K-1766 Salt Test and Speedstir
    Jun 2016
    West Warwick, RI
    3
    Quote Originally Posted by Texas Splash View Post
    The video instructions didn't say anything about adding water before sand. My husband did check the laterals before pouring in small amounts of sand, so I don't think that's it. We didn't backwash or rinse the first time running the filter and did have quite a bit of sand after the first startup. We have done to backwash cleanings so far as per regular weekly maintenance, but it hasn't solved the sand blowing problem. Maybe I'll just look into a Hayward sand filter. They seem to come highly recommended.
    Intex Sand Filter
    Jun 2016
    harlingen tx
    1
    Can a lateral be separated and not be broken ? We are having the same issue :/
