Results 1 to 9 of 9
Thread: Pollen or Algae???
    Jun 2015
    Wamego/KS
    120
    Pollen or Algae???
    I have been keeping my FC around 4 since opening slam. I have noticed some yellow looking stains on the bottom. They brush away into a cloud of yellow. The water then turns a light shade of green. I am keeping PH around 7.5, however it was up over 8 when i tested yesterday so added acid to bring back down. Have not shown any CC since opening slam, even last this morning showed 0 CC. Not sure how to proceed since I am not sure what is going on. If it was algae would I be getting some CC reading? It appears to just settle on the bottom in crevices again after sweeping. Would the filter not get it out if it was pollen? Suggestions???
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    38,524
    Re: Pollen or Algae???
    Not really pollen season right now. Sounds like algae to me. CC and algae can be mutually exclusive. What are you test results? What FC have you maintained?
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Quote Originally Posted by Nate1975 View Post
    I don't think algae necessarily causes CC, but it will consume FC quicker than you expect. Raise your FC to SLAM Level, brush & vacuum, and do an OCLT. The results will tell you a lot.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Jun 2015
    Wamego/KS
    120
    I normally try to keep FC around 4 with my CYA at 30. I usually just check it in the evening after the kids are done swimming and add the needing amount of bleach to bring it to 4. It is typically close to 0 at that point. We have kids swimming most days so would that eat up the FC as well? I brought to shock level this morning and will do the same at lunch. Will do the OCLT tonight and see what results I get. Thanks
    38,524
    You are letting the FC get too low. You should never let it get below the minimum for your CYA level that's listed in that chart in pool school.
    Jun 2015
    Wamego/KS
    120
    How many times a day do you need to check the FC level?
    Jun 2015
    Wamego/KS
    120
    So...on days when we have unusually high number of swimmers do you recommend bringing to shock level for the night even if everything looks good as a preventative measure? Or do you only bring to shock level when you are experiencing issues such as mine?
    38,524
    Right now you need to follow the slam process until you pass the three criteria to stop.
    But going forward you'll need to check the FC once per day but you need to make sure you dose high enough such that it is not below the minimum the next day when you test.
    If you are expecting high use you should be bumping up the FC few part per million beforehand so that it doesn't drop too low.
    Jun 2015
    Wamego/KS
    120
    Gotcha. Thanks!
