Thread: Switched from Chlorine to Bromine. Cant keep CL high, itchy skin. Common? Outdoor spa
    Jun 2014
    Houston, TX
    22
    I switched recently from chlorine to bromine due to consistently high CYA. My CL level can't get above a 2 at night on full settings and 0 during the day.
    But more importantly, is it heard of for people to be itchy from the spa when using bromine? I don't remember having this issue before with bromine. It's an outdoor 7500 spa that runs 24/7 and gets high usage.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Switched from Chlorine to Bromine. Cant keep CL high, itchy skin. Common? Outdoor
    can you clean the tub out using ahh-some cleaner then start over using the chlorine method? you probably have mold and algae left over from your stint with bromine
    What is your CYA at now, before you do the ahh-some treatment you can take it to SLAM level but it will probably be easier to just do the ahh-some then refill, I had to do 2 treatments before it came clean
    I hope this helps
    Jul 2015
    Sarasota, FL
    43
    Ditto on the Aww-some. Have had no issues with CL. Spa is stable at 3-5 FC with CYA at 50. Also, borates at 50 really help "smooth" water feel.
    15000 gal in-ground rectangular concrete/pebble-tech pool. Hot Springs Prodigy 325 gal spa.
    Jun 2014
    Houston, TX
    22
    Quote Originally Posted by cowboycasey View Post
    I hope this helps
    I think my CYA is either at or around 10. It was about 400 before. My tub is also concrete, do you think the ahh-some cleaner will still work as well? It's just so strange I can never keep my bromine levels above 2. And just scary that I can't figure out why I'm itching so much. It gets so bad that I have to drop everything and go straight to the shower. And it only happens about 10 minutes after I dry off. While im in there, I'm perfectly fine. But all my levels besides chlorine are perfectly fine.
    Jul 2015
    Sarasota, FL
    43
    So your spa runs off your pool water?
    Jun 2014
    Houston, TX
    22
    Quote Originally Posted by floridarandy View Post
    My pool and spa water containers are separate. My heater only heats my spa
