Thread: Need help!!!
    Jun 2016
    Phoenix, AZ
    1
    Need help!!!
    Recently received my first TF-100 test kit and today did my first testing.
    Using the K-1000 to get the chlorine reading, the test water was a VERY deep orange color. The pH reading was at 7.2. Proceeding with the Free Chlorine test, I never could get the test water to become clear - after 130 drops of the R-0871, all I could get was a milky white color. I didn't even try the CC test.
    I then did the Calcium Hardness test and after 150 drops of the R-0012 ended up with a very pale bluish color which I figured to be a reading of 3750.
    For the Total Alkalinity test, I ended up with a reading of 220.
    On the CYA test, the vial was half way between empty and the 100 mark.
    I live in Phoenix and we have really hard water, but any suggestions would be greatly appreciated.
    Twolf
    Pool is odd-shaped (I'd call it a semi-kidney shape). 3' to 8' depth. 23,000 gallons. In ground. Sand filter. Hayward cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Need help!!!
    Welcome to TFP!
    Did you put lots of chlorine in the pool?
    Do the diluted CYA test, Pool School - Extended Test Kit Directions
