Results 1 to 9 of 9
Thread: Push CYA up, or keep adding bleach
    Jul 2011
    Stockton, CA
    63
    I've been using bleach for several years now. Pool water is clear, no evidence of green. Trying to keep FC 3.5-4; CC always 0-0.5. I find each day it drops from 4.0 down to 2.5 by evening. Based on pool calculator, I add 42 oz. of 10% bleach each night. Last spring I drained about half our water because of high hardness; we are in a drought, and can't replace water very often. In the process my CYA dropped way down to near zero. I added liquid conditioner, cautiously, trying for a CYA of about 30-35.
    The CYA, by the disappearing dot test, is around 30+. So, should I try to raise it up to 35, and maybe have less daily chlorine loss, or should I leave it as is, and keep adding 42 oz. of bleach each night?
    Many thanks.
    22,500 gal, in-ground, plaster, Intelliflo VS 3050 pump, Sta-Rite 400 sq. ft. cartridge filter, solar panels on roof
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Push CYA up, or keep adding bleach
    Add your location to your profile over there <---- so we can make a better recommendation on your CYA level. Generally, higher CYA means lower daily FC loss.
    Jul 2011
    Stockton, CA
    63
    Here you go with my location.
    I know about higher CYA. My problem is that when we are away, we use pucks, which drive the CYA up. A couple years ago, before I knew about TFP, I used pucks all the time, and had CYA above 80, with all the headaches of Cl, etc. I could not get rid of it, because I couldn't drain the pool. So, I'm very cautious about adding stuff, that can't be gotten rid of.
    Hence, my question about the trade-offs at CYA levels around 35. My records show that at higher CYS, say 40, my FC will drop around 25% each day, from 4 to 3, then I add 28 oz. Cl. right now I'm going from 4 to 2.5, and adding 42 oz Cl. I pay around $3.50 per gallon of 10% bleach. Looks like the extra 14 oz. costs me about $.38 per day.
    Thanks for any input.
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by goofiness View Post
    Only loosing 1.5ppm chlorine a day is very good. If it were my pool I would be happy, trying to finesse CYA for .5ppm chlorine loss seems like more work than any real savings
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    DFW, TX
    24,513
    Agreed, 1.5ppm loss is good, especially if you want to leave some room for tabs later.
    Jul 2011
    Stockton, CA
    63
    Thanks to pooldv and oldguy70 for your rational comments. I just finished adding the nightly dose. Doing so means lugging the gallon jug, plus my measuring cup. With some mobility issues, this could be what pushes me to increasing the CYA, and therefore being able to carry the bleach only in my measuring cup, which holds 36 oz. Picky, picky. I'll think it over a bit more, but very much appreciate your advice.
    Since switching to TFP methods, I spend a lot less on chemicals, and have many fewer containers to deal with. And, touch wood, I not had algae or any other invaders. I have converted a few neighbors, as well. Now, if we could just have some more rain each winter... Thanks, again.
    DFW, TX
    24,513
    Excellent, glad TFP is working for you! Maybe it's time for an SWG and no lugging anything and no pucks while on vacation.
    Nov 2015
    Ok ok
    823
    +1 on a SWG
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Nov 2015
    Ok ok
    823
    Be aware SWG can produce scale, sometimes enough to be a problem. Rare but I am one of the unlucky ones. Working with Hayward and others here to resolve.
