Results 1 to 10 of 10
Thread: Vacation... Applying trichlor pucks?
    Jun 2015
    AR
    12
    Headed out for a week's vacation so going to use a 3" trichlor puck to keep FC level up since I can't add bleach daily. Can I apply directly to skimmer basket or do I need to get a floater for it? Any advice?
    18x33x54 AGP (18,500 gallons) - Hayward Power Flo 2 Speed Pump - Hayward 24" Sand Filter - TF100 Test Kit
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Vacation... Applying trichlor pucks?
    What's your CYA and pH?
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jun 2015
    AR
    12
    CYA = 40
    pH = 7.5
    Jun 2012
    western NY
    1,560
    I use pucks in a float when I am gone on vacation. Since I am always having to drain water off in my pool due to rain I never seem to have a problem with my CYA getting too high. If anything, I probably benefit from the occasional use of the pucks.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Only use the pucks if you plan to keep the pump running either 24/7 or by using a timer. Just letting pucks sit in a floater won't chlorinate the pool and if the floater drifts into a wall it can bleach the liner in that spot. Never leave pucks in the skimmer basket.
    If you can't have the pump running while you're away, raise the FC to shock level the day you leave.
    Love TFP? Become a
    TFP Supporter!
    Jun 2015
    AR
    12
    I was planning to leave pump running (it runs 24/7 on low). With that said, it sounds like I could put the puck in a floater and be good. Is one puck enough?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Use the bottom of pool math, effects of adding chemicals. It will tell you how much FC 1 puck will give. I think most are 7 oz. of trichlor, you'd have to check what you have.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    If your worried that the floater will stick against the wall or steps you can use fishing line to keep it in the middle.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    Jun 2013
    Augusta, GA
    90
    In your pool 1 8oz puck should yield about 3ppm Cl, and about 1.6ppm CYA. When I leave for a week vacation, ill put a couple of pucks in the skimmer with my pump on low 24/7, and put a few more in the floater. 1 puck just ain't gonna do it for ya.
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    Jan 2014
    Buckeye AZ
    807
    i am using 3 pucks for the next week but setting the floater to the minimum flow, so the pucks will last a week.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
