Results 1 to 14 of 14
Thread: Possible algae
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Possible algae
    So, the pool finally finished filling Saturday, I did put a little bleach in here and there as it filled. The water was a light brown sound water color since we have well water and live very near the sound on both sides. Once the pool was full we turned on the pump following the directions and then used one of the test strips I got (test kit will be here tomorrow).
    Results
    CH basically none (well pump has a water softener, I assume this is why. But also saw its not important with vinyl pools)
    TC 0 FC 0 PH 8.4 TA 240 Cya 0
    so I did the sock with stabilizer and also added MA to bring down the TA and PH and added some dichlor to bring chlorine to 2ppm (I used this instead of the liquid bleach bc there was not yet any stabilizer in the water) this was Saturday afternoon, used another strip in the morning before work and the PH had gone back up and the TA was still high between 180-240, FC and TC both 0 again added more MA and some liquid bleach to bring up to 2ppm again. After work Sunday the pool was no longer brownish but a light yellow green, thought maybe it was the brownish lightening, TA was down a little more, PH back up and chlorine back down, added bleach and MA. By this point the stabilizer in the sock had finished disolving, used another strip in the evening, TA still slightly high, FC 3 TC 3 still pale green yellow. We saw a few little clear jelly balls on side of pool with micro dots in them, not sure what they are. So this morning I test again around 7am, TC 1, FC 1 TA still a little high ph 8 but it was still greenish so to be safe I added enough bleach to bring FC to shock level of 12 for Cya of 30. The pool is now very clear, no color tint, still not cloudy either but now there are little blackish globs about 1-3cm in size in the bottom of the pool we use the skimmer and a oil them out when touched they mush and are greenish brown, not sure what these are. The FC has held at 10+ (highest on strip) all day, a little more MA this afternoon bc TA was still high and ph was 8, ph dropped to 7.0 after this.
    Anyone know what the tiny jelly balls are? And how am I doing so far?
    ​5,000 AG cartridge bestway 58390E 6/22/2016 BlueDevil B7550 6-way
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Possible algae
    Doing great! Sounds like some frog eggs to me. Once you get the test kit do the Overnight Chlorine Loss Test amd then you'll probably need to SLAM
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Re: Possible algae
    Frog eggs? Falling from the trees? Hmm. Thanks, my kit will be here today.
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Re: Possible algae
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Re: Possible algae
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Help please, what is this?
    Imgur: The most awesome images on the Internet
    what is this in the bottom of the pool? It started appearing after I brought a new fill to shock level.
    Jun 2012
    Butler, PA
    336
    Re: Help please, what is this?
    Dead or on their way to dead organics that are in your water is my guess, but someone who knows considerably more will pop in here and offer their thoughts.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    banditig's Avatar
    Sep 2015
    Ohio
    466
    first look like misquito larve, maybe worms secound. SLAM will kill all.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
    domct203's Avatar
    Jun 2015
    CT
    3,593
    Quote Originally Posted by Deidra View Post
    While I don't know what that is, I don't think I'd get in the pool until I knew they were dead.
    If this were my pool, I would SLAM. Unfortunately the test kit listed in your signature will not work for a SLAM, nor an OCLT.
    Did you fill the pool from city water? Are you under any trees?
    Are you using chlorine? What is your current CYA & FC level?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    Well water, yes under trees (husband chose spot) last I checked with strips pool was 10+ chlorine on several tests yesterday, and my cya had just finished dissolving, estimated at 30
    if I got this would it give me everything I need? Or do I need a special vial? Amazon.com : Taylor Replacement Reagent Refill Kits - FAS-DPD Refill Kit : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    triptyx's Avatar
    Apr 2016
    1,438
    Re: Possible algae
    You can get that kit, but you'll also need a calibrated cylinder (measured for 5, 10, 25ml).
    TFTestkits.net
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Deidra's Avatar
    Jun 2016
    Currituck, NC
    20
    DFW, TX
    24,502
    Re: Possible algae
    Just FYI, lots of people can't, won't or don't want to click out of TFP to look at pics. If you use Photobucket to host your pics you can copy the IMG code to the right of the pic and paste it into your post. That will embed your pic into your thread so people can view the pic in your post.
