Thread: Green pool
    Jun 2015
    Wamego/KS
    120
    Green pool
    I have been keeping my FC around 4 since opening slam. I have noticed some yellow looking stains on the bottom. They brush away into a cloud of yellow. Now the water is starting to turn a light shade of green. I am keeping PH around 7.5. Have not shown any CC since opening slam. Suggestions???
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Jun 2015
    Wamego/KS
    120
    Re: Green pool
    TA is 150. pH is through the roof...over 8.0. Just tested 2 nights ago and it was 7.5. CC is 0 and FC is 3. CYA is 30
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Green pool
    Sounds like you have algae and need to SLAM the pool to kill it.
    Jun 2015
    Wamego/KS
    120
    Re: Green pool
    Could this possibly be caused by pollen? I know our pollen counts are crazy high at the moment. It almost seems like the water is clear when it all settles to the bottom, then when I sweep and stir it up it changes the water to an almost green tint. Does pollen not get filtered easily? Just wondering if this could be my problem instead of algae and how do you know the difference??
