Thread: Intex 9x18 rectangular pool corner joists
    Jun 2016
    iowa
    3
    So we got the Intex 9x18 - 52" pool. Spent many weekends leveling crushed limestone and tamping for a perfectly level area. Buried 6"x6" blocks for supports of the legs where we knew the ground was softer and the weight would cause it to sink. Well we had a corner sink a lot more than normal and the corner piece was sticking so far out you could see the little white clip thing (idk what it's called) so we drained, blocked and refilled. My question is how far out can these go to be considered safe? I know they are supposed to flex with the pool but it makes me nervous. The last thing I need is 4500+ gallons suddenly flooding my yard and hurting someone. Now that the one corner is fixed the other one is further out and if it flexes enough you can see that white clip as well. It's now perfectly level but this is worrisome.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Re: Intex 9x18 rectangular pool corner joists
    Share a picture please so we can see what you are seeing. That will help us help you.
    Kim
    Jun 2016
    iowa
    3
    this is when I pull it out just a little bit and is visible during use when there's movement
    this one is where it is when it is not being used
    rbinn's Avatar
    May 2015
    Nanaimo BC
    85
    On one end of my 9 x18 the corners stretch a bit. Ive never tried to pull them apart. Pools been up for 15 months without issue. Sorry I cant be of more help..
    9 x 18 Hydro Force AGP, Aqua Pro AP ASFAL 75 pump and sand filter, Hayward Skimmer, Raypak 106A propane heater, Sunquest Solar Panels, Pentair Rainbow test kit.
    Jun 2016
    iowa
    3
    Quote Originally Posted by rbinn View Post
    Thanks. That was while it was in use. Another side sank so bad we ending up draining and refilling after leveling and blocking again. Hopefully it's good now.
