Thread: New AG Pool and it's sparkling green! Help!
    Jun 2016
    Cumberland, RI
    3
    Hello!
    I recently set up a 14'x42" Intex AG ultra frame pool, running a 3000gph filter, 3300g capacity, with a newly added Hayward Skimmer. Water filled it Saturday & Sunday last week - we really didn't add anything to it until it began to get cloudy the next Friday. This weekend I took my water to get tested at a Specialty Store and they gave me granular shock, some calcium, and algaecide. We started with the shock - and boom, the cloudiness cleared and the pool went green!
    I've been reading Pool School and making adjustments (my pH was low at 6.4 - lowest my test strips could register), zero alkalinity, and low chlorine... I've added baking soda and borax and bleach - I'm now running at >10 FC, 7.6 pH, and 80ppm TA. The shop registered my CYA at 30ppm (I tossed what I had left over from the previous season in to get the pool started).
    Water is coming from a filtered municipal source. Copper is very unlikely the problem (I might have some copper ion test strips to make sure - I'll dig around). I've researched and researched and everything I seem to be doing doesn't seem to be making a difference. Any help or suggestions are welcome.
    Thank you!
    Jun 2012
    Butler, PA
    336
    Re: New AG Pool and it's sparkling green! Help!
    The quick and dirty
    Stay out of the Pool Store
    Get a Recommended Test Kit
    Read Pool School
    Follow the method here
    Your water will clear
    You filled the pool last Saturday/Sunday, really didn't put anything into it & ran the filter.
    (I would question that deeper asking did you or did you not put anything in, but the test kit will confirm where you are sitting and what you need to do to clear it.)
    From fill time until now without anything in that pooled water, algae took hold and are starting to thrive.
    This method, when followed properly keeps the algae from being able to get a foothold.
    Pool water has to be filtered and sanitized for it to be healthy to swim in.
    You have to keep an eye on the water by testing.
    (Poor Store numbers are not accurate)
    Shouldn't take much to get it back in line.
    Good Luck.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Jun 2016
    Cumberland, RI
    3
    So I should just continue to pour bleach and maintain shock levels until it clears up? It's already looking better by a few shades. I don't know if it's chemistry balancing or killing algae though that's making the difference.
    Jun 2012
    Butler, PA
    336
    I think you need to know your numbers with certainty and dose/ adjust accordingly per instructions here, if you have decided to follow this method.
    If your CYA is 30 and you are in SLAM you should Maintain (that's what the M stands for in SLAM) a minimum of 12 free chlorine throughout your SLAM.
    If you are using test strips or pool stores, even "Specialty" pool stores to obtain your numbers, your numbers most likely don't have the accuracy required for this method. I use the TF-100, so I am a fan of that one. It allows me to keep my water absolutely pristine with zero guesswork. Once you take the guesswork out of the equation your water will clear.
    Full Sun ~ All Day
