Thread: Intex 32x16x52' 10x U Support failling
    Jun 2016
    San Antonio
    1
    We got our Intex 32x16x52' on a Thursday and our sand 5 tons of it on Saturday morning. We had about 8 friends helping us level the yard and setup the pool.Yes, we used a laser level and pavers. Everything was fine till about 1 inch from the top. We where all in the pool already and having a good time when all of a sudden a strange noise appeared. the pool dropped on one side about 6 inches, one of the U supports bend and send a chain reaction down one side of the pool.
    We are draining the pool right now 15.000 gal of water. I filled a claim with intex. Anyone ever had to deal with the 90 day warranty, our should i just return it to walmart?
    Thanks Timo
    Jun 2016
    bc
    138
    Re: Intex 32x16x52' 10x U Support failling
    Wow.... take it back to Walmart. . But good luck with them I never buy anything of value from them as their warranty and return suck
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Sorry about the pool collapse. Good luck with Intex. I don't think they will help you. I could be wrong, but you'll have to prove it was a manufacturing defect and not an improperly set up pool.
    Curious as to what you did to "level" the ground under the pool. From your description, I believe you just dumped sand and then leveled it out and then set the pool on top of that. Sand is mentioned in the Intex pool instructions as something not to be used to level the ground. It can be used in a thin layer to soften the ground under a pool after the ground is leveled first. If you do you want to use sand you need to dig and level the ground from the highest points to the low points. Not by filling in the low spots. Sand will shift. By any chance were the pavers also put on top of the sand as well. They should be put on solid ground as the sand under them can shift. I am willing to bet that the bodies in motion caused the water to rock back and forth shifting the sand underneath the pool causing the supports to slip. This made the pool to fall out of level. All the water weight collected at that weak point and collapse of the pool was guaranteed to happen.
    Taken directly from Intex....
    Can sand be used to level the ground at the pool site?
    No. Sand has a tendency to shift, therefore causing the pool to lean to one side and creating stress on the pool frame. The legs of the pool will also sink into the sand and the pool will become unstable and possibly collapse causing personal injury or property damage.
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
