Thread: My pool is a green swamp
    Jun 2016
    Overlea
    6
    Hello All,
    I am new to pool ownership as the house I bought has one and I have decided to try to maintain it. I have been to Leslie Pool(LP) and I feel like they are feeding me nothing but BS, most times. I have added liquid Chlorine and a Shock packet...that got the water crystal clear BUT the PH levels are off. I took a sample to LP and told them that there was Algae growing in my pool, they said I needed Sodium Ash...I bought it...added it and left for the weekend, I turned the pump off because it seemed to be pumping slowly. I got back last night...IT WAS GREEN! I am felt defeated and this morning I added another bottle of Liquid Chlorine, a shock packet and left for work with the pump on.
    I need to buy some supplies for this pool but LP is EXPENSIVE...I've been going to Ollie's...can you HELP ME?
    What should I buy?
    Where should I buy test kits from?
    I'm really trying...
    Trying to be positive.
    Intex Ultra Frame 18 ft round 48 in deep and 7,600 gallons, Above Ground pool surface vinyl, Hayward Perflex® Extended-Cycle D.E pump & filter.
    38,521
    Re: My pool is a green swamp
    Welcome to TFP!!!
    There are only a few Recommended Test Kits, the best deal by far is the TF-100 from tftestkits.net. Add the XL option since your pool is green.
    Once you have the kit, post up a full set of test results to make sure nothing needs addressed prior to following the ShockLevelAndMAINTAIN Process.
    Read these as they will explain what you need to do:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
