Thread: Pucks
    Apr 2016
    Houston, TX
    23
    Pucks
    If I am following the BBB method, will I still need to add pucks to my pool? if so which do you recommend?
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: Pucks
    Quote Originally Posted by icyjay View Post
    Short and sweet answer is "None".... unless used for very short periods of time and with recognition of the "other stuff" they also add to your water.
    The TFP method means you only put in your water that which it needs and nothing else. We believe in accurate pool owner testing and using the simpliest, cheapest chemicals available. Why buy expensive pool store "Alkalinity Increaser" when you can buy the very same ingredient in bags at Costco called Arm & Hammer baking soda?!
    Many of us use liquid chlorine (aka "bleach") instead of pucks, or a Salt Water Generator ("SWG) to create chlorine. Pucks add either excess CYA stabilizer or calcium which can get out of hand and cause problems.
    Have you read Pool School yet? I would suggest starting here: ABCs of Pool Water Chemistry
    Bring back any questions you have
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pucks
    Welcome to TFP
    if you have them now, keep them until your going away for the week, they do come in handy, if you are out don't buy any until needed... following us does not mean not using something, it means knowing what is in your pool and knowing what you are adding to your pool
    That is why you really need a great test kit, makes knowing so much easier
