Thread: My SWG specs says CYA 10-50 and FC 1-3? Should I listen to them or TFP??
    May 2016
    Toronto
    130
    I just installed a Jandy Aquapure EI.
    Specs say I need 4000-4500ppm of salt. 1-3FC and 10-50 CYA.
    After reading pool school and a lot of research on this site, It seems I would fair better with 70-80CYA and 5-6FC??
    What do you guys think??
    16x34 In-ground vinyl pool (22,000ish gallons), Sand Filter, K-2006 test kit, SWG
    JoyfulNoise's Avatar
    May 2015
    13,259
    Re: My SWG specs says CYA 10-50 and FC 1-3? Should I listen to them or TFP??
    I would say to follow TFPs advice. But you're free to do as you like. Try the SWG manufacturers specs and see what happens. My bet is that you will be running your pump and SWG constantly in trying to maintain their specs. When you get tired of that, try our methods. B
    Matt
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I have followed recommendations from the CYA?FC table and have had no problems with algae or anything. My SWG mfg recommends different levels as well but I trust the advice and experience of the folks here.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    May 2016
    Toronto
    130
    Ok thanks, also, how do I know or what is dependant on what % I run my SWG at? I can do 20/40/60/80 or 100%. What is ideal?
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    You can adjust your SWG % output &/or adjust pump run time. Our electricity is fairly cheap so I opt for lower % and more pump run time. You will have to experiment a little to see what is the "sweet spot" for your particular situation. Running less % is supposed to increase the cell life but again, if your electric rates are high, you might want to opt for higher % and less pump time. I usually have to adjust a few times in a season depending on pool temps, rain, etc.
    May 2016
    Toronto
    130
    Quote Originally Posted by Ksnewman View Post
    cool thanks. I will play around with it a bit.
