Thread: pool filled but pump not wired yet
    May 2016
    Woodland
    4
    My pb has been an absolute nightmare. He makes promises to send someone out and nobody ever shows time and time again. This time my ig pool was plastered on Wednesday last week and fill was completed in approx. 24 hours. Now the pool has been filed but no chemicals have been added and the pump has not been wired electrically do is not running. I'm worried that the water is going to become difficult to get safe since the water is not circulating and has no chemicals. Is this really bad? How long can it sit before it becomes dangerously unsanitary. I'm new to pools and need advice. Thanks.
    Jun 2015
    Ottawa/Ontario
    340
    Re: pool filled but pump not wired yet
    Start getting some bleach in there and brush walls and bottom to circulate. Do you have the recommended test kit?
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    May 2016
    Woodland
    4
    I don't. I'll go ahead and do that. How long should people stay out of the water after adding that?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    edit: I wouldn't personally swim in a pool I couldn't test, but if it's a super new fill and you get some bleach in there and brush the whole pool it's probably ok.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    May 2016
    Woodland
    4
    We tested it Friday and it was fine but I just don't know how quickly it can go bad. Really new, new pool owner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    Start here, ABCs of Pool Water Chemistry
    And here, TFPC for Beginners
