My pump motor has been sounding pretty bad for a while, I got some advice and I have its replacement on hand as well as a new pump seal and I am bout to tackle the job (watched a few you tubes regarding replacing seal!)
Here is my questions(s) before I start:
1) would a motor going out greatly reduce water output from jets?
2) if output is reduced would that be the cause of a sudden algae (green) outbreak on my liner?
I've been running it 12+ hrs a day (usually overnight) for the last several days. Which is longer than I normally ran it last year, I did this because I knew I had the new motor on hand and wasn't afraid that I needed to "baby" it.
Thanjs for for your help !
