Results 1 to 10 of 10
Thread: Leaky pool connection
    Sep 2015
    Havertown
    17
    Hello,
    I replaced the skimmer housing (this is the before picture) but had to reuse the hose male smooth adapter (appears gray). And I reused the same clamps and white hose. It initially didn't leak but now I think there is leakage from above the hose male smooth adapter as well as from between the hose and the adapter. I'm not sure I used enough Teflon tape or applied it in the right clockwise orientation with the adapter to make a water tight connection. I ordered a new adapter which I will use to replace the gray one. Should I use Teflon tape again or should I use thread sealant (TFE paste with Teflon)? And should I use any sealant or other compound between the smooth adapter and the hose or are the clamps enough? Thank you!
    https://www.amazon.com/Harvey-023030-Pint-Paste-Teflon/dp/B000FPDL7O/ref=sr_1_3?ie=UTF8&qid=1467037211&sr=8-3&keywords=tfe+paste
    https://www.amazon.com/Hayward-SPX10...ords=spx1091z4
    Jun 2014
    15,103
    Re: Leaky pool connection
    Not necessarily my area of expertise, but I'm going to try and get you some help.
    domct203's Avatar
    Jun 2015
    CT
    3,584
    Quote Originally Posted by andrewdaddy View Post
    Hello,
    Welcome.
    I would try first without any tape or thread sealant. Personally I always use just a few wraps of Teflon tape on any threaded fitting that would be impossible to tighten without cutting pipe, otherwise, in a situation like this I would first try without tape first as it is removable/able to tighten after the install (just most likely inconvenient).
    If you do use tape, don't over-do-it. Too much tape and over tightening can lead to expanding the female thread to the point of failure (cracking).
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Pat asked me to stop by
    Are you going to remove during winter or from the looks of it this is a permanent setup..
    If permanent I would use purple primer and oatay PVC cement on both connections and make them permanent, no more leaks
    If not permanent, use this stuff
    Weld-On 87685 Blue Seal Plastic and Metal Pipe Thread Sealant with Brush in Cap Applicator, 1/2 pint Can: Amazon.com: Industrial Scientific
    I hope this helps
    Sep 2015
    Havertown
    17
    The hose connection to skimmer is not permanent. I usually loosen the clamps and put the hose/pumpunit inside for the winter. Would you use the Weld-On sealant on both the threaded and slip-on connection?
    Jul 2013
    Fletcher, OK
    3,353
    I am not sure, I don't think it would hurt, it is basically like contact cement, at least that is what I read somewhere here in the last 3 years
    Sep 2015
    Havertown
    17
    where do you recommend purchasing replacement 1.5 inch pool hoses?
    Sep 2015
    Havertown
    17
    how long should I wait before using the pump and getting the PVC pipe wet after applying the weld-on sealant?
    Jul 2013
    Fletcher, OK
    3,353
    At least an hour but better overnight of you can
    I am using my phone so please excuse any spelling errors and short response.
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    Get RectorSeal T plus 2. You can get it at Lowes or Home depot. Buy some gas line rated yellow teflon tape. Apply the Rectorseal followed by a few turns of teflon tape. I guarantee it will withstand any pressure. The pipe will burst before stuff leaks. Good luck. Oh, and the stuff does not dry out or get hard. It's wonderful stuff.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
