Thread: Loss of Return Flow
    Jun 2016
    Uxbridge
    2
    Re: Filter pressure problem
    We replaced the sand in our filter this season. When starting the filter, it starts with lots of pressure into the pool through the return. After 45 minutes the pressure decreases so it doesn't filter properly or have enough suction to vacuum. Turning the pump motor off then on increases the pressure again but we lose it over 45 mins or so. Have tightened all fittings, checked 'O' rings, cleaned pump impeller. What could be causing this loss of pressure?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Loss of Return Flow
    What does your pool water look like? If you could add more details about your pool to your forum signature, that would help. You can do that here: Edit Signature
    Isolated Spa - 345 Gallons
    Jun 2016
    Uxbridge
    2
    I'm not sure what more I should tell you about my pool other than what I've written in my signature. Here's what I wrote about my pool: Pro-Line | 11.2k gal (21' Round) AG | Chlorine | Sand Filter | 1 1/2 HP 1-Speed Pump (new in 2009) | Installed Pool July 1998 | Last Opened June 19, 2016
    Here's my problem: We replaced the sand in our filter this season. When starting the filter, it starts with lots of pressure into the pool through the return. After 45 minutes the pressure decreases so it doesn't filter properly or have enough suction to vacuum. Turning the pump motor off then on increases the pressure again but we lose it over 45 mins or so. Have tightened all fittings, checked 'O' rings, cleaned pump impeller. What could be causing this loss of pressure?
    Any help you can be is much appreciated. Thank you. Orlando
