Thread: Technical Question about FC&CC testing with K-2006:
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Does a way exist to test CC at 0.2/drop immediately after testing FC at 0.5/drop? Is this a question for Taylor? Is this testing possible with a different kit (e.g., TF-100)?
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Technical Question about FC&CC testing with K-2006:
    No. Unless you created a custom diluted solution of R-0871 for the purpose. Then of course, the onus of accuracy would be on you and the prepared solution. Probably not a good idea.
    Isolated Spa - 345 Gallons
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Thanks! I had thought not, but wanted to ask just in case
