Thread: Trouble with Multiport Valve
    May 2015
    NY
    12
    I've been getting sand in my pool after a backwash and water is coming out of the waste line when the filter is set to filter. My searching is leading me to believe that I have a bad spider gasket. I'm considering replacing the entire Key, Cover and Handle Assembly. I can't determine the exact Hayward model I have since the numbers are all faded off. I've attached a photo of my current one and I think I'm going to replace it with this one from Amazon:
    Amazon.com: Hayward SPX0714BA Key, Cover and Handle Assembly Replacement for Hayward SP0714T Multiport Valves and Sand Systems: Patio, Lawn Garden
    Can anyone identify what model I have and confirm if the one on Amazon will fit?
    Thanks!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Trobule with Multipoty Valve
    Looks to be a top mount valve. Any recent model of top mount filter has this valve: SP0714T. That part you linked is a replacement part for this valve.
    Isolated Spa - 345 Gallons
