Thread: CYA Question
    Jun 2016
    Kuna Id
    15
    CYA Question
    I need to get my CYA up a little and was going to use some granular stuff from wallyword but.... I tried premixing a little in a bucket prior to putting in the pool and ended up with "milk" with lots of sediment in the bottom. I did not put it in the pool because that stuff doesn't seem like it will fully disolve. I read somewhere to put it in a sock and hang it by the intake. Will it cloud the water?
    What is the best way to increase CYA?
    16' x 48" Coleman Power Steel Frame AG. 6000 gal. Intex 633T 2500gph.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CYA Question
    The best way is to do as recommended here: Pool School - Recommended Pool Chemicals
    In a sock, in front of a return or in the skimmer with pump running until dissolved. Will dissolve faster in warmer water and if you squeeze the sock periodically.
    Isolated Spa - 345 Gallons
    Jun 2016
    Kuna Id
    15
    Re: CYA Question
    Thanks JVTrain. Thats where I read the sock method. Does the sock keep it from clouding the water? I am really aprehensive about putting it in my pool after the premix I did in a bucket. My logic tells me it will cloud the water but I am super new at this and learning every day.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Re: CYA Question
    I just added using the sock method yesterday. When you squeeze the sock you can see a cloud come out of it, but it never made my pool cloudy at all.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
