Results 1 to 9 of 9
Thread: New pool. Very high TA. Added muriatic acid. Cloudy lime green. Help!
    Jun 2016
    Avilla
    6
    5.0 FC
    7.6 pH
    Ta was 240, added ma yesterday. Now 180.
    40 cya
    Lime green. Cloudy.
    Kids impatiently waiting. How do I get crystal clear?
    Just filled 2 days ago
    Starter pool
    15x15 round Intex
    above ground
    4400
    gallons
    triptyx's Avatar
    Apr 2016
    1,438
    Re: New pool. Very high TA. Added muriatic acid. Cloudy lime green. Help!
    That's a giant jump in TA, and the pH is suspect.
    How much MA did you add and is your pH reading from before or after adding the MA?
    What is your pH right now?
    What test kit are you using for your numbers?
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Jun 2016
    Avilla
    6
    5 cups of ma. All results this am, after adding ma last pm. Using the hth strips. Getting drop kit this week.
    Starter pool
    15x15 round Intex
    above ground
    4400
    gallons
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Ah... we rarely trust strips as they're too subjective and only give "range" estimates. We prefer a test kit that gives a concrete number- either the TF-100 or the Taylor's K-2006 (no other number).
    We need to know the following:
    FC
    CC
    pH
    TA
    CYA
    Since your water is cloudy, something is in there that needs to be fixed. Did you add chlorine as soon as it was filled? What chemicals have you added? Do you fill from a well??
    Nov 2015
    Carrollton tx
    451
    IMO
    Test strips are not accurate - guesstimate at best
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
    Jun 2016
    Avilla
    6
    Shock as soon as filled right away and algaecide. City h20
    Starter pool
    15x15 round Intex
    above ground
    4400
    gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to TFP Can you add the gallons to your signature ??
    Will need more accurate test results which you'll get from the "drop" kit. What did you use for "shock" ??
    If you're going to try and use the TFP method of maintaining your pool you'll want to stay away from algacide. There are other things in some of the algacides that just do go well with maintaining a clear, clean pool. See - - > Pool School - Defeating Algae
    Solar Blanket, Well Water, Borax Added. 76°
    Jan 2014
    Buckeye AZ
    807
    Quote Originally Posted by jerzgirl35 View Post
    Welcome to TFP.
    The methods proposed on the site are essentially the opposite of what's you've done so far. We don't recommend just dumping in shock, and algaecide is unnecessary except in rare circumstances. IF the algaecide has copper, that can contribute to making the water green, though that's a "clear green".
    Get the recommended test kit so you can really understand what is happening, and then we'll add only what is needed to address the issues.
    Ongoing maintenance of your pool, once cleared, will be very easy.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jun 2016
    Avilla
    6
    Thank you everyone. I have a level issue too. Draining,moving pool, restarting over. Suggestions for chems? Kit? Just bleach? My city tap TA
    is very high. Now I know better.
    3860 gal Intex 15x 42
