Results 1 to 10 of 10
Thread: Our First Pool! Did we level properly?
    Birdlady81's Avatar
    Jun 2016
    Concord
    5
    We just put up our first pool. It's an 18' x48" Intex above ground pool. We leveled the site to a max 2" grade (it was 6"). We setup the pool and put each leg on concrete pavers. Because of the 2" grade I did not bury all the pavers, but rather kept them level to one another, so that the top of the pool is level too. Is this ok to do? I read all pavers should be flush with the ground, but this would make the top of the pool uneven. Thanks!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Re: Our First Pool! Did we level properly?
    Hi, welcome to TFP! If the ground is solid under the pavers it shouldn't be a problem. Keep an eye on the pool as it starts to fill. If you see any areas starting to sink you will need to stop and re-level the pool.
    Love TFP? Become a
    TFP Supporter!
    Jun 2012
    Butler, PA
    336
    Dig down, don't build the sags up.
    Good Luck!
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by DKT113 View Post
    Good Luck!
    Agree! Agree! Agree!
    Birdlady81's Avatar
    Jun 2016
    Concord
    5
    Well the pool is already filling at this point and we returned the tamper and sod cutter.
    I'm just looking for it to hold up this summer and then we are taking it down over winter.
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    It sounds like you're doing great- much better than we did with our first attempt.
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Birdlady81's Avatar
    Jun 2016
    Concord
    5
    I am assuming as long as the liner doesn't bubble out or any weird structural things start happening it will be fine for the next 3 months or so since it is only 2" and it's an Ultra Frame.
    We really have no idea about these types of pools (I had a legit installed above ground growing up, so that's a bit different than this).
    Jul 2009
    Houston, Texas
    9,409
    Post a picture and we can tell you if it looks ok or not.
    Love TFP? Become a
    TFP Supporter!
    Birdlady81's Avatar
    Jun 2016
    Concord
    5
    I'll take a photo tonight.
    Birdlady81's Avatar
    Jun 2016
    Concord
    5
