Results 1 to 19 of 19
Thread: Is it normal to see visibly see chlorine coming out after putting it in the skimmer?
    Aug 2014
    westfield
    60
    See white haze coming into the pool after putting in the skimmer.
    Just wondering if this is normal.
    Thx
    S180t hayward sand filter for agp
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    Re: Is it normal to see visibly see chlorine coming out after putting it in the skimm
    Why are you putting it in the skimmer?
    Liquid or granules?
    Support the site
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    it works better to pour in front of the return and not use the skimmer
    Aug 2014
    westfield
    60
    Granules in the skimmer. Seems to be a pretty common practice from what I've read and heard.
    30,432
    Oops! Are you using cal hypo to chlorinate?
    May 2014
    Franklin, NC
    9,202
    Quote Originally Posted by askinstuff View Post
    While many say to do it this way it is a very bad technique. It causes a very acidic environment and can damage equipment.
    I wouldn't worry about what you are seeing, but would change this practice. Plus, what solid chlorine are you using? TriChlor, DiChlor or CalHypo? The first two add CYA/Stabilizer to the pool water that you may not need and the latter add calcium that your AGP does not need at all.
    Support the site
    Sep 2015
    Rome, NY
    363
    Exactly what my PB Bioguard dealer had us do last year, our first year. Smart Silk Sticks in the skimmer all the time, even with pump only running 10 hours a day.
    Glad i found you guys.
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    May 2014
    Franklin, NC
    9,202
    Quote Originally Posted by doc8404 View Post
    Hmmm, I wonder who would have wanted to repair any damage when the skimmer deteriorated..... Sorry, it's out of warranty....
    Support the site
    Aug 2014
    westfield
    60
    I've used both at one time or another
    May 2014
    Franklin, NC
    9,202
    I guess what we are asking is are you testing to make sure CYA and CH are not getting out of control?
    Support the site
    Aug 2014
    westfield
    60
    Yes I am. Using the tf100 test kit. Ph was actuality a little low, now it's at 7.6. Chlorine at two. Forgot the value for the cya, but remember being in the "good" range
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    More on adding chemicals here, Pool School - Recommended Pool Chemicals
    May 2014
    Franklin, NC
    9,202
    There is no "good" range for CYA, that is a pool store/pool industry theory. FC & CYA must be maintained as a ratio to each other as outlined in the Chlorine / CYA Chart.
    2 FC would be the absolute minimum FC level that would be allowed if the CYA was below 30.
    We are really not trying to jump on you, just letting yo know that you are on the borderline for getting an algae bloom.
    Support the site
    Aug 2014
    westfield
    60
    No worries. That's why I'm asking these questions. I'm new at this. I'll check levels when I get home and post them here.
    Aug 2014
    westfield
    60
    Cya at 35
    Mar 2011
    Grand Rapids, Michigan
    279
    Ye old Bioguard dealer! The more I followed their instructions the worse my water became. Also, my wallet got emptied pretty fast on a weekly basis!
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    May 2014
    Franklin, NC
    9,202
    Cya at 35
    There really isn't a 35. The tube is a logarithmic scale, so half way between two numbers really isn't a "5". Just round up to the next higher number for calculations.
    So for 40 CYA your FC should never go below 3 and you should target 5 to make sure the UV rays during the day don't take you down below 3.
    Pool School - Chlorine / CYA Chart
    We want you to keep asking questions! That is how you learn. Plus, for every person like you who does ask there are many who just read and don't ask. We try to phrase our answers to make sure they understand also.
    Support the site
    Aug 2014
    westfield
    60
    Lol, I guess 40 it is!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Quote Originally Posted by DebbieO View Post
    Know that feeling when they sold me sanitizer (chlorine) with calcium. When I started with TFP I started to read labels since some of the stuff made sense finally. So they're selling me something to increase my CH like I have a plaster pool ?? And it's more expensive that the straight sanitizer. $$$
    The worst thing was the 25-50 dollar bottle of "try this" and it sure felt like that didn't have any more idea if it'd work for me than I did. So glad to have pool shelf empty of Bioguard this and that.
    Now I know what's going in and it's easier on me doing it myself rather than running to the pool store.
    Solar Blanket, Well Water, Borax Added. 76
