Results 1 to 11 of 11
Thread: SLAM needed or did I catch it early?
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    We were somewhat lax with the maintenance this past week due to medical issues and recovery from surgery. Long story short, I checked the pool Friday afternoon with the solar cover still on:
    Friday 6-25, 3:00pm
    FC - 0.5
    CC - 1.0
    PH - 7.6
    CYA 50
    I added 34 oz Liquid Chlorine to bring the FC up to 6,
    Saturday morning 6-26, 11:30 am:
    FC - 0.5
    CC - 0.5
    When I removed the cover, the pool had splotchy algae on the floor. Added 34 oz of 12.5% chlorine to raise level to 6 ppm and dosed an extra 20 oz. to try and knock back the live stuff. Pool was clear, we swam in it. Vacuumed and brushed and scrubbed the stairs. Water was still clear but a touch cloudy..
    Saturday afternoon 6-26, 4:30 pm, Checked levels again
    FC - 13.5
    CC - 0.5
    CYA - 20 ???
    PH - 8.2 ???
    TA- 110
    Saturday evening 6-26, 8:00 pm, Checked levels again
    FC - 11
    CC - 0.5
    I did not add any more chlorine as I figured with us swimming and 90 degree partial sun that loss from 13.5 ppm to 11 ppm was normal.
    Sunday afternoon 6-27, 3:00 pm
    Pool had small growth of algae, (significantly less than yesterday) water is clear and not cloudy. I vacuumed and brushed again and tested. Water was still mostly clear, less cloudy than yesterdays result after vac and brush.
    FC - .05
    CC - .05
    I dosed at 60 oz. 12.5% liquid again to try and knock back the growth.
    I'll check the #'s again early morning tomorrow, the Mrs. is recovered from her medical issues and can do some additional testing and dosing while I am away tomorrow.
    If I find any algae in the morning, then is it time to SLAM?
    I hope we can catch and correct this in time for the holiday next weekend. I'll report back in the a.m.
    All thoughts and suggestions are appreciated.
    Mike
    Mike F.
    15' Above Ground Sharkline Matrix, Vinyl, 6,000 gal. Hayward XStream Cartridge Filter. TFT 50 Test Kit. Install 7/2014
    Raypack 150k BTU Natural Gas Heater installed 6-2016
    Aug 2014
    Northern IL
    4,615
    Re: SLAM needed or did I catch it early?
    Every indication is that you will have to SLAM, but it seems like it will be quick. Take your PC down to 7.2, and go for it in time for the holiday.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Quote Originally Posted by MarianParoo View Post
    Every indication is that you will have to SLAM, but it seems like it will be quick. Take your FC down to 7.2, and go for it in time for the holiday.
    I'm sure that this is a typo.... bring your PH to 7.2 for the SLAM.
    Quote Originally Posted by MJF54 View Post
    Friday 6-25, 3:00pm
    FC - 0.5
    CC - 1.0
    PH - 7.6
    CYA 50
    FC - 0.5
    CC - 0.5
    FC - 13.5
    CC - 0.5
    CYA - 20 ???
    PH - 8.2 ???
    TA- 110
    FC - 11
    CC - 0.5
    FC - .05
    CC - .05
    Mike
    There are no 'normal' or 'acceptable' levels of algae. The reason that the algae is still showing up is because you have not yet eradicated it.
    This pool needs a proper SLAM: http://www.troublefreepool.com/conte...tain-shockingl
    Just because you cannot see the algae does not necessarily mean the water is clear of algae spores. To truly determine if there is organic matter in the pool is to perform an OCLT: http://www.troublefreepool.com/conte...loss-test-oclt
    If this were my pool I would not hesitate to start the SLAM, especially if I want clear water for the holiday weekend.
    For Saturday afternoon you posted FC & CC levels of .05ppm, is that a typo for 0.5ppm?
    What are you testing with, and how do you normally chlorinate?
    You will need a confident CYA level so you can know your proper FC shock level for the slam: http://www.troublefreepool.com/conte...art-slam-shock Lets hope it is closer to 30ppm rather than 50ppm, it will keep the initial FC dose amount down.
    Stop dancing with the algae, and get to killing it!
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    Land O Lakes, FL
    527
    Time to SLAM to totally get rid of the algae.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    Thanks guys,
    I really new what I had to do but was trying to do the dance. Figured I could corral it. I ran the filter all night. This morning had a couple of small spots, water clear, could definitely read a dime if I threw one in.
    Pictures from this morning, the test result pictured is the CC test:
    Pool 6-27-16 - Google Photos
    Here's this mornings results using the TFT T-50 kit.
    Monday 6-27, 8:00am
    FC - 6.5
    CC - 0
    PH -7.8
    TA - 120
    CYA - 20
    The chlorine I added yesterday should have brought me to 9.5 FC, and this morning down to 6.5.Definitely a fight going on in there. Good news is the CC seems to have dropped so I have it on the run.
    I will drop the PH and start the SLAM in a little bit.
    The CYA has been around 50 since opening in late May, why the drop? Should I add stabilizer now or wait till after the SLAM?
    I'll update as I go,
    Mike
    Mike F.
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    Update on SLAM progress
    Monday 6-27, 10:00 am
    Added 21 oz of chlorine to bring to SLAM level of 10.
    Added 18 oz MA to reduce PH to 7.2
    Monday 6-27, 1:00 pm
    FC still at 10
    Monday 6-27, 5:00 pm
    FC - 9.5
    CC - 0.0
    PH 7.2
    Added 4 oz Chlorine to bring level back to 10ppm.
    Pump running 24/7
    I'll check before bed and try an OCLT in the a.m. I think I got it. My guess is the extra doses I added Saturday morning and Sunday afternoon got me up to SLAM even though the PH was a little high for the SLAM.
    I picked up stabilizer today and if I pass the OCLT tonight I'll adjust the CYA up to 30 and then aerate to drop the TA and raise the PH.
    Keeping my fingers crossed that I got it early.
    Mike
    Mike F.
    domct203's Avatar
    Jun 2015
    CT
    3,578
    Sounds good Mike, stay the course.
    How's the water look, no visible algae, even when brushing?
    You are brushing, right?
    Looking forward to those OCLT results.
    Dom
    Dom - TFP Guide
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    Brushed twice today. No new growth this afternoon...
    Mike F.
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    Tuesday 6-28
    Did not pass OCLT
    FC- 6.5
    Cc- 0.5
    PH- 7.2
    Added 21oz 12.5% to bring SLAM level back to 10
    The fight goes on.
    Mike F.
    Mar 2015
    South Texas
    411
    Tuesday 6-28
    Did not pass OCLT
    FC- 6.5
    Cc- 0.5
    PH- 7.2
    The fight goes on.
    Hang in there, I'm betting it won't be too much longer
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    MJF54's Avatar
    Jul 2014
    Southeast, WI
    30
    Sorry for taking so long to update, here is the result:
    I could not pass the OCLT for a couple of days but the pool was looking great.
    So we stayed the course and kept the SLAM level up and the PH down and brushed a couple times daily.
    Thursday morning we passed to OCLT and I started to let the CL drift back down.
    I ran a full range of tests Saturday morning and used pool math to adjust all my levels.
    CL is now at 5
    PH added 10 oz washing soda to bring up to 7.6
    TA was at 90, added 14 oz baking soda to bring to 100
    CYA was at 20, added about 12 oz stabilizer to move towards goal of 30. (It calls for 16 oz, but I'll work up to it)
    Pool sparkles like it should! Fired up the heater and we are back in business for the weekend!
    I have been a TFP convert for 3 years now and am a full believer. I never got upset or confused during this little episode. I knew if I followed the program we would be fine, and we are.
    Thank You All!
    Mike F.
