Results 1 to 7 of 7
Thread: Cool deck vs grass
    Jun 2016
    Las Vegas, Nevada
    1
    Cool deck vs grass
    Can someone tell me what is the main purpose of building a cool deck (of any material) around pool? I don't want any more hard surfaces in my backyard! 99% of our patio is already cemented. My husband is telling me that we must have a deck to protect the pool' foundation from rain water, etc., he says that the coping alone won't sufice. Is this true? I always tought the deck was just for walking and decoration.
    Mar 2015
    US
    122
    Re: Cool deck vs grass
    It depends on your pool construction. Gunite is a concrete shell that is self supporting concrete. Not much deck needed there. Fiberglass need a concrete collar to hold the pool in the ground when it's empty (it'll float like a boat). For IG vinyl, the pool walls need a small concrete collar (maybe 1 or 2 feet) to help stabilize the walls. Curved walls may need a little less than a long straight wall. We did not want a huge deck because we want our free form pool to resemble a country pond. So we are only doing 24 inches of concrete that will be topped with tumbled blue stone. Then we are using Synlawn artificial turf to give us "grass" that will not make the pool dirty with grass clippings. A random search of the Googles came up with a few examples of grass pool decks: Grass Pool Decks
    For drainage, you can always add some drain tile to get the water away from the pool.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Apr 2013
    Sacramento, CA
    2,769
    Gunite pools do not require any deck. Keeping water away from the pool is not generally an issue with a gunite pool.
    Even though you don't have a deck you want some sort of bonding grid surrounding your pool
    triptyx's Avatar
    Apr 2016
    1,438
    How much grass and other debris do you want in your pool on a regular basis? If you don't have kids or dogs, probably not an issue. But part of the attraction of hardscape around the edges of the pool is to avoid people/dogs tracking all kinds of dirt, grass clippings, leaves, etc. into the pool every time they get out/in. Add any kind of heavier traffic (kids, dogs) and now you get to add mud to your water as well. Finally, a strip of hardscape will assist with not having longer grass trying to grow into the pool. Might mean you need to edge less.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Flbeachluvr's Avatar
    Mar 2016
    Port Orange, FL
    363
    Quote Originally Posted by triptyx View Post
    We only have three feet of cement decking around part of our pool and then grass after that. When it's just my husband and me swimming we don't get a lot of grass in the pool but we had a party this weekend with a lot of people walking on the grass and then going into the pool. The next morning I had quite a bit of grass in the pool. My skimmer caught the floating stuff and I just brushed the stuff on the bottom into the drains. A bit messy but not a big deal. Now if I had a bunch of kids over all the time I might have chosen to have more decking.
    Pool completed 3/21/2016
    8800 gallons, plaster 14' x 24', 3/4 hp Hayward pump, Hayward cartridge filter, Blue Essence T-5 SWG, Kreepy Krauly Kruiser, Taylor K-2006 test kit with Speedstir, Taylor K-1766 salt test and 250 sq. ft. of Heliocol solar panels with Pentair Solartouch control system
    triptyx's Avatar
    Apr 2016
    1,438
    To be fair - I only have about three feet around the back and sides of my pool as well - but that's still a good amount of room for kids/people to walk around the pool. The OP is talking about just having a coping, which wouldn't be wide enough to really walk normally on, hence my reasoning above.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    We have about 2' of rock coping around our pool as we didn't want that much hardscape in small back yard area. When my husband mows, I just make sure that I have the pump set for skimming, dump skimmers and all is good. We do use a grass catcher for the yard, though. We have had pool parties and it wasn't an issue. We have more problems with wind dumping pollen & leaves in pool. It works for us.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
