Thread: Sand for sand filter
    Jun 2016
    Semmes, AL
    26
    Can you buy the sand filter sand at lowes, or do you need to buy sand somewhere else for more money,...does it matter?
    Jun 2012
    Butler, PA
    336
    Re: Sand for sand filter
    You need plain old pool sand. I believe some Lowes and Home Depots have them, mine was really fouled at the start of this season so I replaced it, but I have to go to the pool store for it. I just got the economy stuff not the "special" stuff. And I will be staying on top of deep cleaning, it was something I neglected to do, but I won't make that mistake twice. There is a post on here about not all sands being equal you may want to search it up and see if anything inspiring is inside of it for you, but I went with the el cheapo sand and my pool in great form.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I want o say it was the Quikrete brand that wasn't performing correctly. I'll see if I can find the link.
    My findings on how not all sand is created equal
    There is a link to another good thread on the topic within that post, too.
    May 2016
    EUGENE
    15
    There are only two pool stores I town. None of the home improvement stores carry pool sand. So be careful if you're in a similar situation. One store swore up and down it was silica sand, but when I get there it's zeo. The other said they didn't carry silica, but when pressed they found a few bags. The few bags I got were dirty, I wish I classified it myself.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    As a FYI about the quickcrete, Yeah, there were a couple of reports about it being bad.
    Dave had a conversation on the phone with the quickcrete rep. It appears as if a bad batch of Pool Sand did get distributed, but overall, they have a good quality procedure and there should be no reason to avoid it, unless you just want to be ultra safe.
    Pool Sand is #20 silica. Anything smaller than #20 will get through the holes in the laterals and end up on the pool floor.
    Divin Dave,
    May 2016
    EUGENE
    15
    Quote Originally Posted by Divin Dave View Post
    Dave - if the smaller stuff gets vacuumed back into the filter would you expect it to stay gone? Or should I dredge it out?
