Thread: Intex 8x30" pool help
    Jun 2016
    Ontario
    1
    Got this pool tonight for the kids. It has a filter and pump included.
    The pool is 639 gallons
    What kind of chemicals should I be getting or is house hold products the way to go?
    First time owning a pool with a pump
    Any help is appreciated
    Thanks
    May 2016
    EUGENE
    15
    Re: Intex 8x30" pool help
    I did the tiny pool before we got the little pool. This is year 2 on the little pool. Use the pool math calculator to get your borax added, then some baking soda. Bring down the pH with muriatic acid. Then get bleach into it. All I used the first 2 years was the cheap as heck pool test kit that did chlorine and pH. I spitballed the rest, and figured it's so small I could dump it and try again, and be out only a few bucks. The only thing I'd say if spitballed is use powdered shock for a week then quit and go only bleach, it will get you some cya cheap. Only go back to the powder when the chlorine starts going too fast.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Welcome to TFP!
    Congrats on the new pool! Definitely follow the guide PAGirl posted for you.
