Thread: Normal to see DE back in the pool after cleaning the filter?
    Feb 2016
    Los Angeles, CA
    37
    So I cleaned my filter for the second time since it was installed last year. After I added the DE I noticed that the pool got cloudy. I'm running the filter its full cycle to see if it clears up, but is it normal to see DE back in the pool after adding it to a clean filter?
    Thanks!
    22,000 gallon in ground pool with pebble finish. Pentair DE filter with Pentair VS pump. Built in the 70s but completely redone (including new pebble finish, equipment, and plumbing) in August 2015. K-2006.
    Mar 2016
    Spring, Texas
    47
    Re: Normal to see DE back in the pool after cleaning the filter?
    The only time we've seen DE back in the pool is when the pool guy put DE in the wrong skimmer, and when one of the techs forgot to turn one of the levers - we have 2 levers that both have to be set to Skimmer 1 to send DE into the filter and not into the cleaner. When it's been done right, we haven't had any DE come back into the pool.
    21000 gal IG Pebble Sheen (Blue Surf), Pentair quad DE filter, Sta Rite Intellipro VS pump; Paramount PCC-2000 inground cleaner; Installed May 2016.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    No, not normal. This should help, Pool School - Maintenance and Cleaning of Pool Filters
