Thread: Aquarite PCB error and all lights on
    Jun 2016
    Southern OK
    4
    We've had this happen several times now and up until today it's only happened when the booster pump was running. We get the PCB error and the no flow, check salt, high salt, and inspect cell light are all on as is the power LED. Turn power off for a minute or two and it may run fine for the next 8 hours again. I just replaced the flow switch and rinsed the cell which looked quite clean fwiw. I haven't received my Taylor salt test yet, but the instantaneous salinity is within a 100 ppm of what the pool shop is giving us if that matters.
    Jun 2011
    Long Beach, CA
    2,787
    Re: Aquarite PCB error and all lights on
    Try turning off the system and unplug the PCB board from the unit and then reseat the board on the pins. This will sometimes fix strange issues with the PCB board as some of the contacts might not be making a good connection.
    Jul 2015
    OV, CA
    65
    Blooze, Keep us posted on this one.. I had a similar issue, and not sure if its completly resoved. reseating the PCB is the first step.
    20K IG gunite with attached spa, dark plaster and lava rock waterfall, very 90's. Pool equip refit in 2005 with all Sta-Rite cartridge filter, pump, and heater; Polaris sweep; Goldline Controller(Hayward) with T-Cell-15 SWG
    Jun 2016
    Southern OK
    4
    The display PCB is brand new. I removed it and cleaned the pins gently with an eraser ( which works great for all the electronics I've built over the years). Of course it fired up and appeared to run like it should. We shall see as the rest of the week goes by. I do hate trying to line the front panel up though. Pretty weak mounting system. The inrush current limiter looked fine and no obvious burnt spots on the main board so thats good.
    If it happens again, check supply voltage with the booster on. There might be an excessive voltage drop under full load.
    Support the site
    Jul 2015
    OV, CA
    65
    Quote Originally Posted by JamesW View Post
    Did you try and put a ohmeter on the current limiter? I recently replaced my current limiter and checked the rest of the PCB while I had it out. I was starting to wonder if I needed to check the other big Caps as well.
    oOo good suggestion about the booster pump. Now that you mention it the last time I saw mine fail the booster pump was running as well. I think I will check it too. And now that I think of it I put my old booster pump back in service as the current one seized up. Amazingly it fired right up after sitting around for 10 years. Perhaps it throwing some spikes while running.
