Thread: Pool Pump Timers...
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Pool Pump Timers...
    I recently purchased this...
    Intermatic P1131 Portable 20 Amp Outdoor Timer Heavy-Duty Outdoor Timer
    I guess I should have paid more attention but I just figured a twist lock was a twict lock? It arrived and I was excited to install it, fairly simple. One problem, my twist lock is smaller than the one I ordered.
    ugh
    24' x 54" Oceanic Round AGP, 1090 Hayward Skimmer, EC-40 Filter system, Automatic Chlorinator. Pool will be in Full sun for most of the day (9am-6pm).
    Jul 2007
    Hillsborough, NC
    521
    Re: Pool Pump Timers...
    I'm going to install this one
    Woods 59101R Outdoor 120-Volt 40-Amp 24-Hour SPST Mechanical Time Switch with Metal Box - Wall Timer Switches - Amazon.com
    You do have to know a little bit about electricity. I'll wire it so it controls a duplex receptacle so that it turns off the pool pump and the SWG.
    Mar 2015
    Winfield, KS
    45
    If it were me I'd just replace the male plug with one that fits the receptacle.
    Round 18' Sharkline pool, 8600 gallons of well water. Hayward 40gpm single speed pump and DE filter
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Quote Originally Posted by Gomez9356 View Post
    I might consider that except the female end on the timer doesn't fit my current twist lock plug either...
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    338
    This is the one I have installed for my pump. It is pretty straight forward. I have not had any problems with this model for any application I have ever used it on.
    T101
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
