Results 1 to 8 of 8
Thread: Doughboy 28' AGP recessed...struck and removed rock at excavation sight..now what
    Jun 2016
    Parsons ks
    4
    Excavating for 28' doughboy pool to recess and hit rock table while excavating. Decided to try and remove them and get a depth with transit but i have went to far down by removing rock at site. What do i put back in the bottom to build a solid base? Read till my eyes bled on what to do and decided to ask here... Very frustrating to say the least. Wish i had some better guidance! Thanks..
    Mar 2015
    US
    122
    Re: Doughboy 28' AGP recessed...struck and removed rock at excavation sight..now wha
    In my excavation for my IG pool, it was suggested to use non compressible material for any accidental over dig. Then use a plate compactor to make sure it was completely settled (compact it every 2 to 4 inches of fill). Some examples of non compressible material are mason sand, slag sand, crushed limestone with fines (called 21AA around here), pea gravel with sand. Although I am not a fan of plate compacting mason sand, as it seems to fly around a bit too much. Do not fill with any organic material or clay.
    29,000 gallon vinyl liner custom designed lagoon style in-ground pool (self-built 2015-2016), Hayward EcoStar VS pump, Hayward HP21404T Heat Pump (140K BTU), Hayward Pro Grid DE DE6020 Filter with Fiber Clear, Hayward Tiger Shark, 2 Hayward Color-Logic LED lights, Stenner 45MPHP10
    370 gallon Jacuzzi J-345 spa with ClearRay UV
    Jun 2016
    Parsons ks
    4
    Screenings are what i first thought of as well. I have no access to a compactor but can use excavator bucket and also what about damoening screenings with a sprinkler to help them compact some? Seen that done for base setups for concrete pours.
    Mar 2015
    US
    122
    As long as the water drains away okay, I suppose that could work. Not the recommended solution from my excavator friend or from the pool kit company that I used. Whatever you use, remember that you are going to have a whole lot of water weight on the area that is filled. So just be sure that it is well compacted. At a minimum, use a hand tamper with every inch of material you fill in. The excavator should have some pretty good compression force too.
    Jun 2016
    Parsons ks
    4
    I wonder if it would help to let site sit after i compacted screenings in it? Say a week or two of watering with sprinkler and such?
    Mar 2015
    US
    122
    The longer it sits, the more compact it will get. Conversely, the longer it sits, the less you swim this summer. Not sure how much more compact it would be after only a week, though. If you are going to use the water method, I would probably let most of the water evaporate out before continuing. In addition to your repair, you could do a test area outside of your pool site and do some test digs over time to see if the compaction is improving or is up to your needs.
    May 2016
    EUGENE
    15
    If you have a good source of bentonite clay, or cat litter it compacts into a solid. I've used it to make rocket engines.
    Jun 2016
    Parsons ks
    4
    Ok i think i am going to go with screenings and compact and see if it suits the needs... Awaiting a call back from hoffinger tech line on their idea.... I do not have a source for bentonite clay but i see where your going with that idea..... I cant imagine i am the only one who has ran into this issue but i will keep this post updated as i go.. Thanks!!
