Results 1 to 13 of 13
Thread: CYA...again
    Jun 2014
    Houston, Texas
    475
    CYA...again
    Why can I not get this up? I have not once gotten it to where it should be. We've added 3 bottles of the conditioner <bc it's new water and we wanted to get them right quicker> and I have been testing every day and it's still at 45-48.
    Today's reading:
    FAC 5.5 <that went up from 2 days ago> from 5
    CH is 275 <300 two days ago> yes, I know it needs to be 350+
    TA is 70
    salt is 3000
    pH 7.2 -- this goes up and down (first time it's been low)
    I did the pool calculator and we just added the 2lbs of CH and I guess I will buy another bottle of conditioner but darn !
    And on top of that, my husband has the who died and made TFP right? Where do they get their info? Who says Their calculations/chemicals levels are right? Someone just shoot me now!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Jun 2014
    15,129
    Re: CYA...again
    According to my Poolmath calculator directions, based on your 19K pool, it's telling me you needed to add either 178 ounces of granular stabilizer OR 460 ounces of liquid conditioner to go from a CYA of zero to 70. Not sure how big those bottles were that you added, but I hope this helps confirm what you have done so far.
    Jun 2014
    Houston, Texas
    475
    Re: CYA...again
    I never had a CYA of 0. I've added 3 bottles over time from 6/18/16 CYA started at 30 after the SWG was turned on and I tested the water. I was told it's better to add than to take away - esp. with CYA
    19k SW IG
    Jun 2014
    15,129
    Re: CYA...again
    Okay, then starting at a CYA of 30, you would've needed to add 263 ounces of liquid stabilizer to get to 70.
    Jun 2014
    Houston, Texas
    475
    Re: CYA...again
    i did ! but it never got there. we coulnd't believe it either and we waited a couple days and it went up but now it's down again but the FAC is good....
    19k SW IG
    Jun 2014
    15,129
    Re: CYA...again
    That is very odd. CYA generally doesn't just drop. Often times we see variations in testing, or it can lower over time from frequent backwashing, minimal oxidation each month (very little), and swimming splashout. The only other way CYA would drop would be a pool leak. Not sure if you've had to add an unusual amount of water lately. I would hope not since you just had your pool re-plastered. Once in a great while we receive concerns about a bad batch of stabilizer/conditioner that just didn't seem to hold well.
    Jun 2014
    Houston, Texas
    475
    Re: CYA...again
    Well, I am trying desperately to get there. It's very frustrating to me. I may be a slow learner but I am at least trying. AND I turned 3 people standing to get their water tested and told them about this site - one guy I even took his phone and typed it in his notes!
    I wanted it to be perfect for our 4th party.
    We haven't added any water, in fact, we've drained water bc we have had So.Much rain here!
    19k SW IG
    Jun 2014
    15,129
    Re: CYA...again
    You don't sound like a slow-learner to me. And you have the best test kit available. But rest-assured we all miss something from time to time, so if you ever do have a question about anything, that's what we're all here for.
    As for the CYA, it is best to be cautious. The last thing you want to do is over-shoot your target with that one.
    Only time will tell. Whenever I try that the people look at me as if I'm an alien. Hopefully you had better luck.
    Jul 2008
    Seacoast, NH
    250
    Re: CYA...again
    Quote Originally Posted by DMS2014 View Post
    This could be it. When you had rain, it diluted the CYA. Then you drained off water and some CYA went with it. Did the drop in CYA occur right after you drained water?
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Jun 2014
    15,129
    Re: CYA...again
    That is a good point Deb04 - not dilution but water exchange. Back about a month or two ago when we all got hit really hard with those rains for about 4 weeks straight, any repetitive drain(s) would start to add-up and reduce your CYA. Mine went down about 20 ppm when we had that 30 days or so of heavy stuff.
    cj3737's Avatar
    Jun 2016
    North Ogden, UT
    629
    Re: CYA...again
    I would test cya a few times and take an average..... use the same sample and just put it back in the bottle. Make sure you are using your body to shade the sun and take the reading that way. Ive had to do that a few times just to get better at seeing (or not seeing) the dot... Once the dot starts to fade, go drop by drop and see what happens... lighting is key to this test
    Inherited 24' Muskin Above ground
    13500 gal
    Hayward S180T92S Sand filter
    Taylor K-2006C Speedstir
    TFPC for Beginners | Pool Math | Pool School | CYA Chart | SLAM | Test Kits | ABC's
    May 2015
    Chicago, IL
    11
    Re: CYA...again
    Also, unless I'm reading this incorrectly, you are taking your pool samples to the pool store for analysis. If you are, stop! Get yourself a kit testkit from TFTestkits.net (Either the TF-100 or the Taylor K2006). Do the testing yourself. Also, look a diluting the CYA test so that you test more than just a handful of times ... (one of many threads CYA dilution discussion ).
    Remember, the PH test is also unreliable while doing a SLAM (high chlorine) so get that in order first. Good luck.
    '91 Chicago-land Vinyl In-ground Pool: 41x16. 6' deep end / about 20,000 gallons. Hayward Perflex DE filter. Polaris Watermark G1000 Chlorinator (used by previous owner, not me). Hayward H200 Heater. Aux Pump for pressure side robot. (2) skimmers opposite of each other mid-pool, (1) bottom drain, (2) returns on opposite ends of pool lengthwise.
    Jun 2014
    Houston, Texas
    475
    Re: CYA...again
    actually, according to my log, we added a bottle of conditioner on 6/19 and 120lbs of salt. 6/20 CH. on 6/21, it poured and we drained for 50 minutes. Added 40lbs of salt. That nighted added Another bottle of conditioner and 9lbs of CH. Somewhere in here I am missing a bottle of conditioner bc I know we put in a total of 3 bottles. Last night added more Ch. and today it rained like you-know-what for about an hour.
    19k SW IG
