Thread: New Filter: issues with sand and air.
    May 2016
    EUGENE
    15
    I finally got a sand filter to replace the cheap one that came with the cheap pool.
    So I got the biggest cheap filter I could.
    Here's the issues:
    1: there is sand in the pool. How much is too much? If I were to estimate it would be a tablespoon or less. It does come back a bit after a vacuum, but seems to be decreasing.
    2: if I let the pump run for more than a couple hours the sight glass is getting many air bubbles and I need to stop and bleed. Also whenever the pump is turned off lots of air goes into the sight glass and pool. I'm pretty sure I don't have any leaks.
    100$ Intex 12'x30" (year 2)
    Intex 3000 gph filter/pump
    May 2016
    EUGENE
    15
    Re: New Filter: issues with sand and air.
    And right after I wrote this I turned the pump off and no air at All. Almost 3 weeks and now it works like I think it should just after posting about it.
    Jun 2014
    15,152
    THAT's how good we are here at TFP. We anticipate problems before they happen and fix them while you type.
    May 2016
    EUGENE
    15
    Dude. I call it "technician proximity effect" at work.
