Thread: Cloudy Water
    Jul 2013
    Southwestern Indiana
    11
    Cloudy Water
    It took me a while to get my pump running this summer, and I ended up with algae in the pool. It looks like the green algae is gone, but I can still tell my water is cloudy and I'm losing chlorine quite a bit faster than usual, so I think there is likely still some in there, eating up the chlorine. I tested my water (TFT test kit) this evening, and have gotten my pH levels up to 7.5. However, I'm not 100% sure what my next step is, because I noticed my TA and CH are both low, in addition to the chlorine. Which should I work on next? Or does CH matter as much for an above ground pool with a vinyl liner?
    ph = 7.5
    FC = 1
    CC = .5
    TC = 1.5
    TA = 90
    CH = 120
    CYA = 45
    My pool is a 24' above ground pool, so 13500 gallons.
    Thanks
    24x4 round AG Doughboy, 13.5K gallons, installed 2007
    Multiport Sand filter, Hayward Power Flo LX pump, HP: 1.5, SPL: 70 GPM
    Manual vacuum, nylon brush, Auqaluminator light, wedding cake stairs
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    Re: Cloudy Water
    CH is fine for a vinyl pool. TA is not low either. Your FC is low for your CYA? It needs to be above minimum at all times to keep the pool sanitary. FC/CYA Chart
    Here are the recommended levels from Pool School - Recommended Levels
    If you have algae then you should SLAM the pool to kill it.
    Jul 2013
    11
    Re: Cloudy Water
    Ok, I'll focus on the chlorine through the SLAM method. Thanks!
