New Motor, only hums when attached to pump! HELP!
need to make sure the pumps not locked up or in a bind when coupled together. if thats good but still will not turn check to see if the motor is correct to your voltage and that it is single phase not 3. also look to see if its level with the pump and no shims are needed. hope this helps
