Thread: Lighting Question
    Jun 2016
    Los Angeles, CA
    25
    Lighting Question
    I'm putting together plans to build a pool and have some questions about lighting. I'm looking at the small LED lights that screw into a 1.5" piece of PVC in the wall. The lights are supposed to be 4" below the water surface, so water will obviously enter the PVC when the light is removed when the pool is full. How would the pipe usually be run to prevent it from filling a large portion of the pipe? I would think that water left cutoff from the rest of the pool with a light installed would grow all kinds of algae and the next time there was a removal, the pool would be innundated with that algae.
    TF-100 kit, SpeedStir, Sample Sizer. Still in early stages of pool planning
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Re: Lighting Question
    Nearly every type of pool light allows water into the conduit including the nicheless lights you are questioning. For this reason the light junction boxes are required to be 8" above the waterline, 4" above grade and have the conduit lines from the pool sealed with silicone or a rubber grommet.
    Water in the conduit is rarely an issue so long as proper chemistry is maintained. There really isn't a good way to seal the niche but still allow for servicing in the future.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2016
    Los Angeles, CA
    25
    If maintaining pool chemistry solves any issues with future removals, I guess I won't worry about how one would route the pipe to keep the amount of water in the pipe to a minimum.
