Results 1 to 8 of 8
Thread: Plumbing to outdoor kitchen
    I have a covered back porch and am planning an outdoor kitchen to be installed there. As luck would have it, my current washer hook up is right on the inside of the wall where I want the outdoor sink to be. I am trying to figure out how to hook up the sink so I can disconnect it in the winter and drain the lines for freezing protection but I don't want to pull the washer out twice a year (disconnecting in fall and reconnecting in spring). Has anyone brought indoor plumbing through a wall for their outdoor kitchen? Any ideas?
    Blaine
    50' x 22' 27k gal shotcrete freeform, 2hp 2 sp Pentair Whisperflo, Pool Pilot RC-52 SWCG, Pentair TR 100 sand filter, Prowler 820 robot, Florida Sunseeker LED lights.
    My pool build:
    osage-hills-pool-build-t50526.html
    Jun 2014
    15,298
    Re: Plumbing to outdoor kitchen
    I would think if you had access, it would be nice to insert a "Y" and essentially split the water source going to the washer so that you had two paths - one to the washer and one out back to the sink. Each could have a spigot on the end for the hoses to connect or remove from as needed. Of course getting to the water line and inserting a "Y" is easier said than done.
    If that became too tricky, perhaps run a new water line from an existing spigot already out back to the sink area. Just a thought.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    When we installed outdoor shower, we ran a separate hot/cold water lines using PEX (our whole house is plumbed with PEX) from under the house and then had shut-off valves under the house for the shower. We just drilled a hole through the brick to run the PEX to the shower diverter outside with another set of shut-off valves. We just drain each fall and shut off. We are going to do the same for future outdoor kitchen.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Jul 2015
    Long Island City, NY
    70
    Install frost proof sillKocks (getting curse word warning with proper spelling) in the wall from washer supply. Use a hose adapter to connect outdoor pex lines to kitchen.
    Google
    Texas Splash, that was my first thought, just put a Y on and connect two sets of hoses. But that is where I would have to pull the washer out and take off the Y and the hoses to the outdoor sink twice a year.
    Ksnewman and vermaraj, some type of frost proof shut off would be the way to go. The outside faucets are frost proof but they need an inside intersecting wall to mount in and there is none in this area that would work. I should research if there is another type. Running the lines through the wall and into the kitchen island with a set of frost proof valves there would be awesome if possible. The house is on a slab so very big project to get under the house to change any plumbing.
    Blaine
    My pool build:
    I do see that you can order frost proof faucets of varying lengths. The ones I have seen are at least a foot long and need a perpendicular intersecting wall to mount in. I found that they come in varying lengths so you can get one just long enough to go through the wall, keeping the valve inside in the heated environment. These I could mount so I can turn them on and off under the sink and disconnect the hoses through the access door under the sink. That should work! I included link I found, note the chart where the varying length valve stems are listed:
    http://www.woodfordmfg.com/woodford/.../14CATALOG.pdf
    Blaine
    My pool build:
    wjr75's Avatar
    Jun 2013
    IL
    836
    You need to somehow get a drain valve inside that is lower than the sink lines so they can be drained prior to freezing temps. I have a basement so that's how mine are piped. I just open the spicket drain valve at the end of the season and drain into a bucket. I also dump some car window washer fluid in the sink drain which is good to below -20 degree's f. Can get RV stuff too but I have used window washer fluid and been fine.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Quote Originally Posted by wjr75 View Post
    I would probably disconnect the lines from the spigot and allow them to drain or blow them out. The frost free silcock will automatically drain the part that could freeze. I am thinking for the sink drain that it may connect into the washer waste line above the trap so I would not need to have another trap outside which would eliminate freezing issues there. But I'll know more about that when we get into it. I have a friend who is a licensed plumber who is going to do the work.
    Blaine
    My pool build:
