Results 1 to 7 of 7
Thread: Pool pump
    Jun 2016
    Michigan
    50
    Pool pump
    I recently moved into a home with a pool that seemed to maintained ok. I cleaned the cartridge filter and it looked like it hasn't been cleaned before. I am trying clean what I believe to be what is called a pool pump. It's part of the filtration system (it's supposed to catch large items such as leaves). It seems to be filled up with leaves and I think its clogging up the whole system because water is pumping out really weak. The problem is that I can't open the lid on it.Any tips ?
    38,248
    Re: Pool pump
    Post a picture of the pump. Some use a special tool handle open the lid.
    BTW, that many leaves should not be reaching the pump like that. They should be caught in the skimmer or in a leaf canister on a vacuum.
    Jun 2016
    Michigan
    50
    Re: Pool pump
    How do I add a picture? The vacuume that was available has a nozzle not a plate. So all waste goes straight to the filter.
    38,248
    Re: Pool pump
    Well, then you need to add a vacuum plate.
    To post more/larger pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    38,248
    Re: Pool pump
    Yeah, that one is supposed to have a tool you put on the top to open it.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Love TFP? Become a
    TFP Supporter!
