Poolpals:
Love this site. I have been using the professional test kit and chlorine method in my pool as advocated on this site for a few years, and could not be happier. My pool is gorgeous, easy to maintain, and crystal clear.
So, I have decided to try the methods in this site for my spa. I have a 350 gallon fiberglass Marquis above ground 418 model with two pumps, paper filters, and an ozonator. The spa comes with a place for bromine cartridges, but I have never been satisfied with my ability to maintain the spa. So, using the instructions on this site I have decided to go with chlorine. First, I drained the spa and cleaned it a bit with fresh water, no soap. Then filled with excellent local tap water, and two new paper cartridge filters. I put in dichlor to 10 ppm after adjusting pH slightly. Total alkalinity is a bit high at 110, but not bad. Water was clear. That was yesterday. Today water has very slight cloudiness, free chlorine of 3, pH 7.8 or so, and no free chloramines. I have put in more diclor to increase free chlorine to say 13 or so and will check again tomorrow. Temperature is 102 in the water.
Now, I recognize spas are different than pools, but with no free chloramines and a clear start, why does the water have a slight cloudy appearance? My plan is to add dichlor again the next time, and that should get my CYA up to around 30, which is what is recommended for spas on this site. I will then sanitize with bleach. Thoughts here?
