Results 1 to 8 of 8
Thread: Pool Light GFCI tripping
    MugZona's Avatar
    Jun 2014
    60
    Hi all,
    Over the last few weeks, my pool light GFCI had been tripping after about 5 minutes of the light being on. Today I replaced the gasket and also confirmed there's no water in the housing. When I tested the light after replacing and securing the gasket, the GFCI is tripping as soon as the switch for the pool light is turned on. If helpful, attached is a picture of the GFCI box it's the grey one in the middle. So, thoughts on what I should I do next? What other pictures/info would be helpful for figuring out what's going on?
    Thanks.
    Matt
    13,000 Gallon IG Double Roman End with Steps PebbleTec Seafoam Green Pentair Clean & Clear Plus Cartridge Filter 320 1 HP Sta-rite pump (MPR6E-147L) TF-100 test kit Kreepy Krauly Cacuum
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool Light GFCI tripping
    More for the folks watching at home the funny box on the top left is your pool light junction box, where the cord from the back of your light fixture terminates.
    From the symptoms you describe my thought is that there is either a problem with your fixture or the light bulb in your fixture.
    First I would go back to the fixture (after turning off the power at the breaker) and this time remove the bulb and inspect both the bulb and the fixture itself. look for pitting or burn marks. If its ok replace the bulb and the gasket. While you have it out look at the back of the fixture. Look for cracks or separation where the cord joins the fixture.
    Try and see if it operates without the GFCI tripping.
    If the GFCI trips I would look in the J box and inspect for problems and tighten all connections.
    If that doesn't work I would probably replace the fixture. But wait a couple days someone on here might have a better plan.
    MugZona's Avatar
    Jun 2014
    60
    Thanks — the fixture and bulb look OK, but I don't know... here are some shots if they help. I'm not sure I can get to a new bulb right away but I'll test one out as soon as I can.
    Apr 2013
    Sacramento, CA
    2,769
    That looks like an older fixture. I don't know of any made that way today. Is there a label on the fixture with specs on it you can post?
    Looks like the older American Products fixture, looks exactly the same to mine that is tripping. No water in it, but it's causing the GFCI to trip.
    MugZona's Avatar
    Jun 2014
    60
    Quote Originally Posted by king908 View Post
    I checked your other thread — how were you able to diagnose your tripping issue to the fixture? Also, two years back the light was on for a while when the pool was being drained and there was no water covering it. Then it went off by itself. It did work fine after that, but I wonder if that did some permanent damage to the fixture that is only now manifesting itself.
    Jun 2012
    western NY
    1,560
    I suspect that the light went off when it was out of the water because of a thermal protection it may have built in to protect it from getting too hot. GFCI's trip when there is an imbalance of current flow out of the GFCI and back to it on the neutral wire. water in a fixture is only one avenue in a pool light that could cause the problem. A compromised wire in the conduit could do it too. A good electrician could Megger the line and determine if it is at fault.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Apr 2013
    Sacramento, CA
    2,769
    I think that is an older fixture. I'd replace the whole thing with a new fixture. Inyo Pools has some good videos on how to replace a pool light fixture.
