Results 1 to 7 of 7
Thread: High side spec for FC in SWG pool
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    In looking at the reference guide in Pool School for cya/FC levels, it just shows the min required FC and the Target. What would be the max recommended FC levels for a cya of 70 and 80. In other words, how high is too high for continuous daily levels.
    22,000 gal Cardinal Oasis 36x18 IG Vinyl
    Pentair IC40 SWG Sand Filter 1 1/2Hp Superflo pump Single Speed 3450 RPM
    Build date 9/25/15
    Taylor K-2006 with Salinity
    City water for fill
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    Re: High side spec for FC in SWG pool
    Hhhmmmm.
    Maybe this more extensive chart would help. Chlorine/CYA Chart
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Quote Originally Posted by AimeeH View Post
    Hhhmmmm.
    Thank you... But I'm no genius.. Haha.. I have no idea what I'm looking at there.. Just looking for a high end spec just like there is a low end spec.
    Build date 9/25/15
    City water for fill
    Saturn94's Avatar
    Mar 2015
    Virginia
    501
    You can safely swim at shock level, so you could say that's the "max", though its unecessary to maintain that level. Just shoot for "target" level and you'll be fine.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Joey316g's Avatar
    Jun 2016
    Williamstown, NJ
    41
    Quote Originally Posted by Saturn94 View Post
    Right but you wouldn't want to maintain it at shock level daily. There has to be a number that's unhealthy to run at daily
    Build date 9/25/15
    City water for fill
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by Joey316g View Post
    Use PoolMath...SWG Pool w/CYA 70, 3-10
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Jul 2015
    Central Valley CA
    1,109
    As others have said between the high side of recommended and Shock level is still a safe range. You could swim at that level but if you kept it that high all the time you would go through pool toys, bathing suits, and perhaps even equipment faster than normal. Anything north of the recommended level can dry skin and could lead to skin flaking or cracking with prolonged exposure as the excess chlorine attacks the oils in your skin. That's the biggest health risk I am aware of but in my opinion it's enough of a reason to stay in range. Possible exceptions being boosting for a vacation, unexpected contamination (kid did not make it to the bathroom ), or a slight increase for high bather load.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
