Thread: Start Up CYA confusion
    May 2016
    new orleans, louisiana
    9
    I am just getting my first readings using the TF-100. Water is a bit cloudy. Per pool math I added 20oz of 8.3% bleach at 9am. Added 56oz of liquid stabilizer about noon. My CYA test is giving me a 0 reading taken shortly after adding the liquid stabilizer. Is there a proper time to add liquid stabilizer after adding chlorine? Is there an optimal time to test CYA after adding stabilizer?
    Thanks
    PH 7.5
    CH 250
    TA 150
    FC 4
    CC 1
    TC 5
    CYA 0?
    15' x 42" round 3300 gal, AG Intex Easy Set, Intex 633T Cartridge Pump, 2500gph, TF-100 test kit, Intex Crystal Clear SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Start Up CYA confusion
    ASSUME what you added is in there and keep your FC levle mainatained for that level. Mya be next day before that registers even with liquid. Welcome.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Welcome to TFP!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Stabilizer takes a little while to show up on the test. Wait a day or 2 and retest it.
    In the meantime, just consider that you have x amount in the pool and you'll be fine.
    Divin Dave,
